This may help if you are starting from scratch:
http://136.159.225.44/AlliedData2.pdf
If you are trying to replace an open winding on an existing aircore form coil, it's much easier since the wire gauge, coil diameter, and # of turns are already figured out for you. Just dewax the coil, unwind it, and rewind it with new wire, making sure that you wind the new wire in the same direction as the original. The results won't be pretty if you handwind it, but it will work fine. WIRE DIAMETER, TURN COUNT, and WINDING DIRECTION are the key things that you need to duplicate. I've successfully handwound several standard-broadcast radio oscillator coils this way.
After the coil has been installed and is working, you might want to "paint" it with molten beeswax to keep moisture (and corrosion) out.
Remove the oscillator coil and unwind about 30-40% of it. Then solder a wire to that point, creating a 3-way "tap". Rewind the coil. Solder the tap wire to the bandswitch segment that shorts the tap to ground in "Police" band mode. That should get you in the ballpark for the police band of this Emerson, which is just above the broadcast band (so the number of coil turns is less than for the BC band). This mod also should not dramatically affect the broadcast band, although you will probably have to adjust the padders to get exact dial tracking due to the presence of the tap.
Not certain, but I don't think analog TV IF frequencies were the same as AM radios. But it would be easy enough to calculate a LC combination that is needed to achieve resonance at 455 KHz, and wind a coil based on that.
As I remember, the video IF was around 40 mHz, the audio IF was 4.5 mHz, due to using the picture carrier as the sound local oscillator. Overmodulation of the picture created a buzz in the sound.
