Sounds like it was installed backwards. Part should be a 4 uF 50 electrolytic with the negative (can) going to chassis ground. The 6AL5 clips the negative going part of the AC signal and passes the positive "half" through-so the cap needs to have its + side oriented as the schematic indicates.
Check out the schematic for the Hallicrafters S-82....the 4mfd + goes to ground, between pins 1 and 2 on the 12AL5 which is the exact same tube as the 6AL5. I've looked at dozens of schematics and it's a 50-50 toss up between + going to ground or not going to ground, depending on who designed the chassis. Anyone else have any ideas? Thanks.....
-Bill
Best regards,
Bill
:::On this radio the 4 mfd bypass on the 6AL5 has the + positive lead soldered to the chassis, but on the schematic it has the - negative lead going to ground....The cap is paper but it says Cornell on it and all the other caps say Crosley...so did someone replace it and put it in wrong ? Thanks.
:::-Bill
::Sounds like it was installed backwards. Part should be a 4 uF 50 electrolytic with the negative (can) going to chassis ground. The 6AL5 clips the negative going part of the AC signal and passes the positive "half" through-so the cap needs to have its + side oriented as the schematic indicates.
:Check out the schematic for the Hallicrafters S-82....the 4mfd + goes to ground, between pins 1 and 2 on the 12AL5 which is the exact same tube as the 6AL5. I've looked at dozens of schematics and it's a 50-50 toss up between + going to ground or not going to ground, depending on who designed the chassis. Anyone else have any ideas? Thanks.....
:-Bill
Yes, current flow through the 6AL5 is one way, from the plate to the cathode. There is no current flow from cathode to plate. So, when the cathode goes negative with respect to ground, it will drag the plate below ground potential also. So, the negative side of the capacitor needs to be connected to the plate, with the positive side grounded.
However, I doubt that the electrolytic cap sees more than several volts of reversed polarity in this application, so it would have probably worked for quite a while- probably years- before it failed, assuming that it was incorrectly installed in the first place. (Many times, production documentation was corrected "on the fly" and these changes never made it back as corrections to the original design engineering drawings.)
If the discriminator transformer were out of adjustment you would have distortion on all stations, weak and strong alike. But it could be more noticeable on stronger stations.
