Capacitor voltage
3/31/2013 5:19:29 PMMitch
Hello all,
If two caoacitors are in parallel and rated at 100 volts each, will the new rated voltage be 200 volts?
What if in series?
Too old to remember.
Mitch
3/31/2013 5:24:37 PMLewis
:Hello all,
:If two caoacitors are in parallel and rated at 100 volts each, will the new rated voltage be 200 volts?
:What if in series?
:Too old to remember.
:Mitch
In parallel, no. In series, yes, but you might have to put resistors in parallel with each cap to equalize Voltages.
3/31/2013 5:25:36 PMRichard
:Hello all,
:What if in series?
Series decreases capacitance but increases voltage.
Parallel increases capacitance, voltage is the lowest of the voltage ratings.
Richard
3/31/2013 5:46:24 PMMitch
::Hello all,
::If two caoacitors are in parallel and rated at 100 volts each, will the new rated voltage be 200 volts?
::What if in series?
::Too old to remember.
:Series decreases capacitance but increases voltage.
:Parallel increases capacitance, voltage is the lowest of the voltage ratings.
:Richard
Thank you gentlemen,
Info printed and to go in my capacitor folder.
