Philips P145
3/22/2013 11:01:29 AMMike Antich
Just got the P145 and need a schematics for it. Hope someone can help.
3/22/2013 5:36:20 PMJules
:Just got the P145 and need a schematics for it. Hope someone can help.
:Look this link,http://pacifictv.ca/schematics/philipsp133.pdf
it's the Philips P143. May it could help you
Jules
3/26/2013 7:07:29 PMMike Antich
::Just got the P145 and need a schematics for it. Hope someone can help.
::Look this link,http://pacifictv.ca/schematics/philipsp133.pdf
:it's the Philips P143. May it could help you
:Jules
:Hello Jules,
thank you for the link. It appears that P143 is totally different. Thank you again for response.
Mike
3/27/2013 4:01:35 PMJules
:::Just got the P145 and need a schematics for it. Hope someone can help.
:::Look this link,http://pacifictv.ca/schematics/philipsp133.pdf
::it's the Philips P143. May it could help you
::Jules
::Hello Jules,
:thank you for the link. It appears that P143 is totally different. Thank you again for response.
:Mike
:Hello Mike:
If your radio is Australian, look this link:
http://members.iinet.net.au/~reginald/Reg'sVintageRadio/3Kriesler11-60_files/kriesler_11-60_mantle_radio_schematic_complete.gif
Jules
3/27/2013 5:37:29 PMCapestir
The Canadian Phillips P145 should have the following tubes.6X4, 6AQ5, 6AT6, 6BA6, 6BE6, 6BA6
It's circa 1956 Don't have the RCC index for that year.
The 825 has the same tubes ..appearance wise looks similar..But it has two bands not 3 as I think the P145 has. Schematic might be similar and I can send that to you. Rogers Majestics and Phillips for that time period were sometimes using the same chassis
Ken
3/27/2013 5:47:32 PMCapestir
:Actually the 825S has one Broadcast and two SW bands like the P145. Four buttons on the front and slide dial on the bottom like the P145.
:Ken
4/1/2013 11:07:03 AMMike
::Actually the 825S has one Broadcast and two SW bands like the P145. Four buttons on the front and slide dial on the bottom like the P145.
::Ken
4/1/2013 11:09:46 AMMike Antich
::Ken
Yes, P-145 has same tubes and it may be similar in design except that P-145 uses 1M3/DM70 tuning indicator.
Mike
