stewart warner 801
3/6/2013 4:03:53 PMchuck
I am in need for a source for substituting the inter stage transformers.Does anyone know the values of the transformers?I can't find much on the web about this radio.
3/6/2013 6:01:38 PMMitch
:I am in need for a source for substituting the inter stage transformers.Does anyone know the values of the transformers?I can't find much on the web about this radio.
Hello Chuck,
I have restored one of these in the past, The primary is around 1100 ohms and the secondary is around 500 ohms. I replaced two of them in the same radio, worked great.
Go to this site, use the four wire transformers, $19.00?
http://www.arbeiii.com/transformer.htm
Mitch
3/7/2013 5:49:53 PMCHUCK
::I am in need for a source for substituting the inter stage transformers.Does anyone know the values of the transformers?I can't find much on the web about this radio.
:Hello Chuck,
:I have restored one of these in the past, The primary is around 1100 ohms and the secondary is around 500 ohms. I replaced two of them in the same radio, worked great.
:Go to this site, use the four wire transformers, $19.00?
:http://www.arbeiii.com/transformer.htm
:Mitch
THANK YOU.DID YOU WIRE THEM IN PRIMARY TO PRIMARY OR DID YOU REVERSE THEM SINCE THE RESISTANCE IS THE OPPOSITE ?
3/7/2013 7:04:59 PMMitch
:::I am in need for a source for substituting the inter stage transformers.Does anyone know the values of the transformers?I can't find much on the web about this radio.
::Hello Chuck,
::I have restored one of these in the past, The primary is around 1100 ohms and the secondary is around 500 ohms. I replaced two of them in the same radio, worked great.
::Go to this site, use the four wire transformers, $19.00?
::http://www.arbeiii.com/transformer.htm
::Mitch
:THANK YOU.DID YOU WIRE THEM IN PRIMARY TO PRIMARY OR DID YOU REVERSE THEM SINCE THE RESISTANCE IS THE OPPOSITE ?
Hello Chuck,
In order to be sure of the primary and secondary connections i measured the coil resistances of the good existing transformers. This will indicate where the primary and secondary coil connections should be.
They are all the same in orientation.
Mitch
3/8/2013 2:59:54 PMCHUCK
::::I am in need for a source for substituting the inter stage transformers.Does anyone know the values of the transformers?I can't find much on the web about this radio.
:::Hello Chuck,
:::I have restored one of these in the past, The primary is around 1100 ohms and the secondary is around 500 ohms. I replaced two of them in the same radio, worked great.
:::Go to this site, use the four wire transformers, $19.00?
:::http://www.arbeiii.com/transformer.htm
:::Mitch
::THANK YOU.DID YOU WIRE THEM IN PRIMARY TO PRIMARY OR DID YOU REVERSE THEM SINCE THE RESISTANCE IS THE OPPOSITE ?
:Hello Chuck,
:In order to be sure of the primary and secondary connections i measured the coil resistances of the good existing transformers. This will indicate where the primary and secondary coil connections should be.
:They are all the same in orientation.
:Mitch
I looked up the transformers and I used the same ones in an atwater kent model 20.I will order one and see if I can get it going.
