thanks,
steve sherman
Steve:
If you use a 12 Volt transformer, and replace the 35Z5 with a diode, find a 12 Volt output tube (12V6?), you can just about build the radio as original, and the 12 Volt tubes are easier to find than the 6 Volt equivalents. The audio output transformer will have to be different than the 50L6 for impedance matching purposes.
Using a silicon diode doubler still leaves you with your power supply connected directly to the power line... no isolation.
Rich
:Every series-string-heater tube has a 6V heater equivalent. For example, the 6L6 has the same transfer characteristics as a 50L6. The only trick is generating B+. You could go "whole hog" and buy a transformer that has not only the 6V filament winding but also a HV B+ winding and a 5V dedicated winding to run the heater on a rectifier tube like a 5Y3 or 5U4. However, it would be simpler (not to mention less expensive) to use a silicon diode voltage doubler to generate the B+ and just use a 6V transformer to run the heaters.
Looking at the Hallicrafters S-38 Tube complement,
V1 12SA7GT Converter
V2 12SA7GT IF amplifier
V3 12SQ7GT Detector/AVC/AF
V4 12SQ7GT BFO/ANL
V5 35L6GT Audio output
V6 35Z5GT Rectifier
Rick is correct. A 6L6 wouldn't be happy in your radio. The best sub for the 35L6 would be a 50L6. The 25L6 heater draws double the current, so it would work but can't be used in series with any of these tubes. But with a 25 volt filament supply, you could pair up the other four and run the 25L6 in parallel with the two pairs of 12 volt tubes. Drop the rectifier tube, don't need it.
You could use a 6V6 for the output and all 6 volt tubes in your lineup.
A 12L6 looks like it would work fine on 120 vdc on the plate, but it draws a whopping 0.6 amps on the heater, so you will need a hefty transformer to supply it and the other 4 12 volt tubes.
To use the original tubes, you need a 12 volt and a 35 volt filament transformers, and a 110 to 200 volt B+ transformer. The 35L6 puts out 1.5 watts at 110 v, but that jumps to 3 watts with 200 volts on the plate.
I've had some good luck constructing isolation transformers by taking two transformers from old stereo tuners or tape machines and connecting them back to back (or front to front :>). Find two similar secondaries and hook them together. If there is a mismatch, you can step up the output, giving you a higher B+. Then you search for other windings coming out of the two transformer to supply the heaters. Replace the rectifier and you got it built. Good Luck. John
:I wouldn't compare a 50L6 to a 6L6. Substantially different power capability and voltages.
:Using a silicon diode doubler still leaves you with your power supply connected directly to the power line... no isolation.
:Rich::
My original point was that one doesn't have to look too far afield to find a 6.3V heater "analog" to one of the series-string tubes; although successfully using any tube in a circuit means fully understanding that tube's operating requirements and characteristics. As far as I can tell, there never was any committment by the tube industry to locking in performance parameters across a range of heater voltages/currents, although quite often it worked out that way.
Best 6.3 volt sub for 35L6 or 50L6 is 6W6. It will operate on low plate voltage. Suggest using 6.3 volt tubes which don't require rewiring except filaments. As others have mentioned, they are available.
For 35Z5 could use a 6W4. Slight wiring change but a good way to use up a damper diode.
: Yes, my comparison of the 50L6 to a 6L6 was a hasty oversimplification made to illustrate a point. Both tubes are beam-power, octal-based audio output tubes with identical pinouts, but their respective designs have been tailored to specific target-application classes. If they were hand tools and not tubes, both types might be classified as hammers; although one is like a claw hammer and the other is like a sledgehammer.
:My original point was that one doesn't have to look too far afield to find a 6.3V heater "analog" to one of the series-string tubes; although successfully using any tube in a circuit means fully understanding that tube's operating requirements and characteristics. As far as I can tell, there never was any committment by the tube industry to locking in performance parameters across a range of heater voltages/currents, although quite often it worked out that way.
Initial post mentioned using 6.3 volt tubes but those will do the job if 12.6 volts is used for filaments.
12L6 is the 12 volt version of 6W6. 12X4 is 12 volt version of 6X4 & 6X5. Nothing wrong with using 12.6 volts if the filament transformer is available.
Could even use a 12AX4 damper diode for rectifier. There are a lot around and not much use.
:Also, keeping everything 12-volt..... how about a 12x4?
Steve Sherman
:Peter
: Initial post mentioned using 6.3 volt tubes but those will do the job if 12.6 volts is used for filaments.
: 12L6 is the 12 volt version of 6W6. 12X4 is 12 volt version of 6X4 & 6X5. Nothing wrong with using 12.6 volts if the filament transformer is available.
: Could even use a 12AX4 damper diode for rectifier. There are a lot around and not much use.
::Also, keeping everything 12-volt..... how about a 12x4?
If you use the original tube line up (four 12v tubes and two 35v tubes) you'll notice that they all add up to 118v when in series. (close to today's 120-125v mains)
So each tube drops the voltage according to its number.
Now, if you decided to use a 12v filament transformer and connect all the tubes in parallel, then you can still use all the original 12v tubes but in place of the 35z5 you can use a 12x4 and in place of the 35L6 you can use a 12L6.
All the filament currents in parallel will require a combined total of about 1.5amps of current so a 12 volt 2-amp filament transformer will be fine.
:Steve:
:Try to find a 12sq7 out there somewhere.
:If you use the original tube line up (four 12v tubes and two 35v tubes) you'll notice that they all add up to 118v when in series. (close to today's 120-125v mains)
:So each tube drops the voltage according to its number.
:Now, if you decided to use a 12v filament transformer and connect all the tubes in parallel, then you can still use all the original 12v tubes but in place of the 35z5 you can use a 12x4 and in place of the 35L6 you can use a 12L6.
:All the filament currents in parallel will require a combined total of about 1.5amps of current so a 12 volt 2-amp filament transformer will be fine.
Clifton
:Hello Steve. Now that we know your real quest - to learn more and not shock yourself - we can help you better. Forget filament transformer installations for now. Concentrate on re building the original radio, then making it safe to use.
:The 12SQ7 is an octal Duo-Diode High-Mu Triode tube. 12SR7 and 12SW7 could be subbed in there, but they are Medium Mu, which means the amplification factor is much lower, so you will lose performance, output volume. As Peter says, find a 12SQ7. Visit a local radio club and offer trades, since you have boxes of tubes to trade.
:With new capacitors installed and the radio ready to play, plug it into an isolation transformer for improved safety. I described how to build one in my earlier post.
:Good luck. John
::Steve:
::Try to find a 12sq7 out there somewhere.
::If you use the original tube line up (four 12v tubes and two 35v tubes) you'll notice that they all add up to 118v when in series. (close to today's 120-125v mains)
::So each tube drops the voltage according to its number.
::Now, if you decided to use a 12v filament transformer and connect all the tubes in parallel, then you can still use all the original 12v tubes but in place of the 35z5 you can use a 12x4 and in place of the 35L6 you can use a 12L6.
::All the filament currents in parallel will require a combined total of about 1.5amps of current so a 12 volt 2-amp filament transformer will be fine.
Thanks again,
Steve
:Perhaps one could use a transformer with dual 120 volt primaries and a 12 volt secondary. The other 120 volt primary could be used for the B+ voltage and the 12 volts could be used for the filaments. Hammond may make such a transformer.
:Clifton
::Hello Steve. Now that we know your real quest - to learn more and not shock yourself - we can help you better. Forget filament transformer installations for now. Concentrate on re building the original radio, then making it safe to use.
::The 12SQ7 is an octal Duo-Diode High-Mu Triode tube. 12SR7 and 12SW7 could be subbed in there, but they are Medium Mu, which means the amplification factor is much lower, so you will lose performance, output volume. As Peter says, find a 12SQ7. Visit a local radio club and offer trades, since you have boxes of tubes to trade.
::With new capacitors installed and the radio ready to play, plug it into an isolation transformer for improved safety. I described how to build one in my earlier post.
::Good luck. John
:::Steve:
:::Try to find a 12sq7 out there somewhere.
:::If you use the original tube line up (four 12v tubes and two 35v tubes) you'll notice that they all add up to 118v when in series. (close to today's 120-125v mains)
:::So each tube drops the voltage according to its number.
:::Now, if you decided to use a 12v filament transformer and connect all the tubes in parallel, then you can still use all the original 12v tubes but in place of the 35z5 you can use a 12x4 and in place of the 35L6 you can use a 12L6.
:::All the filament currents in parallel will require a combined total of about 1.5amps of current so a 12 volt 2-amp filament transformer will be fine.
steve sherman
Gentlemen,
:For the S-38 architecture, can I use a modern-day IF transformer?
:On Mouser, I see a few XICOR transformers that are inexpensive.
:Which would have the appropriate primary/secondary impedances?
:Will it work in a 100v environment?
: Thanks again,
: Steve
::Perhaps one could use a transformer with dual 120 volt primaries and a 12 volt secondary. The other 120 volt primary could be used for the B+ voltage and the 12 volts could be used for the filaments. Hammond may make such a transformer.
::Clifton
:::Hello Steve. Now that we know your real quest - to learn more and not shock yourself - we can help you better. Forget filament transformer installations for now. Concentrate on re building the original radio, then making it safe to use.
:::The 12SQ7 is an octal Duo-Diode High-Mu Triode tube. 12SR7 and 12SW7 could be subbed in there, but they are Medium Mu, which means the amplification factor is much lower, so you will lose performance, output volume. As Peter says, find a 12SQ7. Visit a local radio club and offer trades, since you have boxes of tubes to trade.
:::With new capacitors installed and the radio ready to play, plug it into an isolation transformer for improved safety. I described how to build one in my earlier post.
:::Good luck. John
::::Steve:
::::Try to find a 12sq7 out there somewhere.
::::If you use the original tube line up (four 12v tubes and two 35v tubes) you'll notice that they all add up to 118v when in series. (close to today's 120-125v mains)
::::So each tube drops the voltage according to its number.
::::Now, if you decided to use a 12v filament transformer and connect all the tubes in parallel, then you can still use all the original 12v tubes but in place of the 35z5 you can use a 12x4 and in place of the 35L6 you can use a 12L6.
::::All the filament currents in parallel will require a combined total of about 1.5amps of current so a 12 volt 2-amp filament transformer will be fine.
Sorry for the bad news, but I want to save you the time of an unecessary experiment.
All the Best,
Bill
Steve
:Hi Steve,
: I think not. Modern IF transformers are designed for use with transistors, which use lower voltages of course and are unlikely to insulate the 100+ volts necessary.
: Transistors require a lower impedance, too, making thse unsuitable.
: Sorry for the bad news, but I want to save you the time of an unecessary experiment.
:All the Best,
:Bill
Warren, I am curious. Is your hotrod radio using a higher than original B+ for the 6V6 output tube?
