Sears & Roe Silvertone 7124
2/16/2013 1:27:39 PMCindy
I am looking for a better schematic or a parts list for a Silvertone model 7134. The schematic on this site is barely ledgible. Tube lineup is as follows: (2)- 12SK7, 12SA7,12SK7, 35L6, 35Z5. Any schematic similar would be appreciated.
Thanks for all the help.
2/16/2013 2:02:29 PMTom McHenry
7124 (title) or 7134 (message)? The 7124 schematic is pretty difficult to read; the 7134 is only slightly better, but "educated guesses" should help fill in the fuzzy areas. Did you have a specific part/area of the schematic that needs clarification?
BTW, the schematic for the 7134 on the Radiomuseum.org website appears to be the same one listed here on Nostalgiaair- fuzzy print and all.
2/16/2013 3:04:14 PMCindy
:7124 (title) or 7134 (message)? The 7124 schematic is pretty difficult to read; the 7134 is only slightly better, but "educated guesses" should help fill in the fuzzy areas. Did you have a specific part/area of the schematic that needs clarification?
:BTW, the schematic for the 7134 on the Radiomuseum.org website appears to be the same one listed here on Nostalgiaair- fuzzy print and all.
Not being a pro at it, I would say the whole schematic. I need just about everything. I can read schematics very well, don't know everything about all the tubes, and each radio is so different. Restored a few superhets,and about 30 smaller ones, with some help from the guys on this site.
There are a lot of dogbone resistors, and a few other items. The solder is so hard to remove to test each item to see what it is and if it works. It is clean, but very old.
Thanks for the info. Appreciate it.
PS. Dad was a TV and Radio repairman...He is no longer with us. It is all his fault.
2/16/2013 3:13:24 PMDennis Wess
Still unknown....
Which model are you after 7124 or 7134 ?
2/16/2013 9:49:21 PMCindy
:Still unknown....
:Which model are you after 7124 or 7134 ?
It is the 7124 sears and roebuck silvertone.
2/16/2013 9:51:58 PMCindy
::Still unknown....
::Which model are you after 7124 or 7134 ?
:It is the 7134 sears and roebuck silvertone.
2/16/2013 10:10:09 PMNorm Leal
Hi
Other Sears radios with the same tubes: 6050, 6051, 6052, 6071, 6085, 3361. One of those schematics may be more readable.
:::Still unknown....
:::Which model are you after 7124 or 7134 ?
::It is the 7134 sears and roebuck silvertone.
2/16/2013 10:15:39 PMDennis Wess
Can send sharper scan of the 7134. Will need your email address.
Dennis.
