2/12/2013 8:07:49 PMBrianC(104783:0)
Picked up a WEGA model 809-1 German radio. Has low, distorted sound on both bands. Looks untampered with and good condition. Looking for a schematic. Thanks....
2/12/2013 9:35:18 PMBrianC(104784:104783)
Found a leaky cap in B+ line...got audio back. Still could use the schematic to check some smaller issues out.
2/12/2013 10:40:42 PMEdd(104785:104784)
:Found a leaky cap in B+ line...got audio back. Still could use the schematic to check some smaller issues out.
Sir Brian Ceeeeeeeeeee . . . .
This is your sets big brudda and resplendently has a tuning eyeball, but the audio circuitry should be the same lineup. I hit the markup of most probable culprits in the AF circuitry as it also is incorporating a tad of negatory feedsack.
Also . . . . .is its speaker cone dragging ?
Be sure to get a more popular set next time . . . .
? ? ? WHY IS THERE AN EXPIRATION DATE ON SOUR CREAM ? ? ?
WEGA Similar Schematic:
2/13/2013 4:39:36 AMLewis(104790:104785)
::Found a leaky cap in B+ line...got audio back. Still could use the schematic to check some smaller issues out.
: : : : : : : : : : : : :Sir Brian Ceeeeeeeeeee . . . . : : : :This is your sets big brudda and resplendently has a tuning eyeball, but the audio circuitry should be the same lineup. : : :I hit the markup of most probable culprits in the AF circuitry as it also is incorporating a tad of negatory feedsack. : : :Also . . . . .is its speaker cone dragging ? : : :Be sure to get a more popular set next time . . . . : : : : : : : :73's de Edd : : : : : :? ? ? WHY IS THERE AN EXPIRATION DATE ON SOUR CREAM ? ? ? : :?????Edd: If crutons are stale bread, why do they have an expiration date? Lewis : : : : : |
: : : : : WEGA Similar Schematic: : : : : : : : : : : |
2/13/2013 9:17:26 AMBrianC(104793:104785)
Thanks for the schematic Edd...I need to print it out to use on the bench, but it doesn't want to be printed...any hints?
2/13/2013 11:56:13 AMWarren(104794:104793)
Download the image to your hard drive. Then you can print the schematic.
2/13/2013 12:28:44 PMBrianC(104796:104794)
:Download the image to your hard drive. Then you can print the schematic.
OK...Thanks Warren
