6N045T
1/25/2013 12:59:42 PMVianney
Hi to all,
I'm trying to restore an old Tektronix 535 scope which is missing all it's tubes ( 62 tubes ).
The seller kept all the tubes for himself.
The scope seems in a good shape.
I paid $20 for the scope with no tubes.
I wonder if it worth the money to restore it...
I wish i could find datasheet for tube number: 6N045T
This tube is next to a relay. It serve as time delay for the relay.
Do you have any datasheet for this tube ?
I don't find any on the net.
Vianney
1/25/2013 1:09:13 PMDennis Wess
1/25/2013 2:58:25 PMLewis
:Try this link.....
:http://tubedata.milbert.com/sheets/084/6/6NO45T.pdf
The relay is a 6 Volt Normally Open 45 second delay relay. Don't know what the "T" at the end means.
Hope this might help.
1/25/2013 6:00:22 PMJohn K
Here's some good info about that scope written by a British guy, I think. His has 73 'valves'.
http://richardsears.wordpress.com/2011/06/18/tektronix-and-early-hewlett-packard/
I think your best source for tubes will be another 535 scope, maybe with a bad component or two. I would not want to put in a tube order for that thing. Good luck with it.
1/26/2013 12:45:28 AMVianney
Thanks to all !!!!!
Vianney
1/26/2013 10:36:08 AMRich
:Thanks to all !!!!!
:Vianney
The 6NO45 is not really a "tube." It's a time delay relay made by Amperite. Some may still be available.
http://www.relaymaster.com/Time-Delay-Relays/AMPERITE/6NO45.htm
Rich
1/26/2013 11:32:45 AMNorm Leal
Hi
Check eBay. There are many 6NO45T's listed. You can buy 120 tubes for $9.99. Get a 6NO45T and sell off the rest.
http://www.ebay.com/itm/120-NOS-USED-RADIO-TUBES-6NO45T-1U4-5T8-5X8-EL95-6DX8-6X8-50B5-35B5-6CQ8-35C5-/321060027083?pt=LH_DefaultDomain_0&hash=item4ac0ab3acb
This is a time delay to allow filaments to warm up before B+ is applied. You don't have to stick with 6NO45T. 6NO30T or 6NO60T would be usable if you found one of these.
::Thanks to all !!!!!
::Vianney
:The 6NO45 is not really a "tube." It's a time delay relay made by Amperite. Some may still be available.
:http://www.relaymaster.com/Time-Delay-Relays/AMPERITE/6NO45.htm
:Rich
1/26/2013 8:26:37 PMJohn K
If it is just a timer for the B+, then a manual standby switch would do in a pinch?
:Hi
: Check eBay. There are many 6NO45T's listed. You can buy 120 tubes for $9.99. Get a 6NO45T and sell off the rest.
:http://www.ebay.com/itm/120-NOS-USED-RADIO-TUBES-6NO45T-1U4-5T8-5X8-EL95-6DX8-6X8-50B5-35B5-6CQ8-35C5-/321060027083?pt=LH_DefaultDomain_0&hash=item4ac0ab3acb
: This is a time delay to allow filaments to warm up before B+ is applied. You don't have to stick with 6NO45T. 6NO30T or 6NO60T would be usable if you found one of these.
:::Thanks to all !!!!!
:::Vianney
::The 6NO45 is not really a "tube." It's a time delay relay made by Amperite. Some may still be available.
::http://www.relaymaster.com/Time-Delay-Relays/AMPERITE/6NO45.htm
::Rich
