Schematics are too fuzzy to read
1/10/2002 9:42:30 PMDavid Ridgeway
I am unable to print out schematics in a resolution that I can read. I have followed the instructions on the website, but still am not able to get a good enough image resolution to read the smaller print. Any suggestions. There are 5 schematics that I am needing.
1/10/2002 11:01:33 PMNorm Leal
Hi David
Have to agree many schematics are hard to read. Did you try clicking on the schematic? This will make it larger. If you have windows 98 or a late version of 95 use "file save attachments". Then go to programs, select "accessories", "imaging". From there you can open, enlarge, reduce and print.
After all this if some are still not readable list what you need. Someone should be able to send you a better copy.
: I am unable to print out schematics in a resolution that I can read. I have followed the instructions on the website, but still am not able to get a good enough image resolution to read the smaller print. Any suggestions. There are 5 schematics that I am needing.
