Thanks, Len
Len:
Wot I think I would do, check on some of the DMMs that measure inductasnce, capacity, frequency and other stuff for which you would only use an instrument only occasionally, then you could have a fist full of test equipment for a few dollars more. Apologies to Clint Eastwood.
The freq. counter functions in many multi-purpose meters is usually limited to fairly low values (audio range). My Wavetek will go up to 20 KHz.
Rich
::Hey guy's, I'm looking to buy a frequency counter, just purchased 2 Eico 324 generators for $50 and would like to see if they perform properly. I have looked ebay and have come across a new Victor VC3165 counter from Hong Kong for $60. any thoughts, or should I be looking for a different type of counter.
::Thanks, Len
:Len:
:Wot I think I would do, check on some of the DMMs that measure inductasnce, capacity, frequency and other stuff for which you would only use an instrument only occasionally, then you could have a fist full of test equipment for a few dollars more. Apologies to Clint Eastwood.
:Lewis
Does it really make a diffrence if my generator is off by 25KC when adjusting the cans on a AM radio using a VTVM?
Len:
As long as you can adjust the cans comfortably to resonance, the exact IF really too important.
I finally settled on a Heath SG-8 signal generator to calibrate AM and FM in radios, they all work the same so it just depends on what you are comfrontable with and trust.
I use a Heath model IM-2410 as my frequency counter to check the signal generator before i align any IF's.
If i want to use modulation from the signal generator i check it with a "O" Scope to verify the 400 KHz signal. Scopes are invaluable for testing and troubleshooting but can be expensive.
I would want a frequency counter to check my signal generator if not just for dial calibration, maybe not Hong Kong.
Hope this helps,
Mitch
