What does the pin designation S mean on the tubes in the Crosely 66TCS on the schematic.
Thanks.
l
Al
Al:
I believe that since the "S" is grounded, and the grids are labeled "G1, G2, and G3", the "S" would be shield.
:::::Good morning every body,
:::::What does the pin designation S mean on the tubes in the Crosely 66TCS on the schematic.
:::::Thanks.
:::::l
::::S = screen:
::::http://www.nj7p.org/Common/Tube/SQL/Tube_query.php?Type=6sa7
::::Carl T
:::Thank you Carl.
:::Al
::Al:
::I believe that since the "S" is grounded, and the grids are labeled "G1, G2, and G3", the "S" would be shield.
::Lewis
:Lewis,
:You're right, except in the 6SA7, it does connect to the screen grid too.
:Carl T
You are right Grid #5. SA7 is the only tube I know of that is connected differently between metal and glass tubes. I've never seen an interchangeably problem due to this difference?
::S in the schematic is shown as pin #1. It's the shell for metal tubes and base on tubes with lower metal section. For metal 12SA7 it also connects to grid #3.
:::::::Good morning every body,
:::::::What does the pin designation S mean on the tubes in the Crosely 66TCS on the schematic.
:::::::Thanks.
:::::::l
::::::S = screen:
::::::http://www.nj7p.org/Common/Tube/SQL/Tube_query.php?Type=6sa7
::::::Carl T
:::::Thank you Carl.
:::::Al
::::Al:
::::I believe that since the "S" is grounded, and the grids are labeled "G1, G2, and G3", the "S" would be shield.
::::Lewis
:::Lewis,
:::You're right, except in the 6SA7, it does connect to the screen grid too.
:::Carl T
:Pin 1 on this tube is grid 5 according to RCA Tube Manual. It actually show it as S G5.
