Oper Manual For B&K 707 Tube Tester Needed
12/23/2012 11:07:08 AMBrianC
Just wondering if anyone has a working link, or site, where I can get a free download of the B&K 707 tube tester operators manual. No luck searching, so far.....
12/23/2012 11:55:11 AMScott
Here ya go:
http://bama.edebris.com/manuals/b&k/
12/23/2012 1:13:20 PMBrianC
Thanks Scott, but that appears to have software attached to the download, which I try to stay away from.
12/23/2012 8:32:13 PMNostalgiaAir
:Thanks Scott, but that appears to have software attached to the download, which I try to stay away from.
Brian, there is no software attached to the download, but it is in djvu format which requires a djvu viewer. I ran the djvu file through an online converter and converted it to PDF (the quality is not as good as djvu, but it is better than nothing). You can download it from here: http://www.nostalgiaair.org/forumpics/707.pdf
Richard
12/24/2012 12:07:35 AMBrianC
Thanks Richard for the explanation and download. That looks fine enough for my use!
12/25/2012 6:40:10 PMEdd
:Thanks Richard for the explanation and download. That looks fine enough for my use!
Sir Brian Ceeeeeee. . . .
You could hobble along with the referencing's text, BUT, if you are ever up against the real need of the technical aspect of its schematic, you can further rely upon this:
I was born by Cesarean section... But not so you'd notice.
It's just that when I leave a house, I go out through the window.
B&K Tube Tester Model 707 . . . . .
