Al
I see that they have changed all the small electrolytic capacitors and I did replace all the power supply 20 uf capacitors myself.
Should I go ahead and test the small capacitance electrolytics now.
Thanks.
Al
Check for drifted resistors in all of the circuitry involving this tube. Check for a weak/gassy tube. Check the tuning capacitor for shorts/dirt in both gangs, though if it works in a certain area for one band, but not for the other, then it is not likely the cause of your trouble.
The fact that you are getting any stations at all pretty well eliminates the IF section of the radio, so concentrate on the RF and converter stages, especially the antenna and oscillator coils. Use a high impedance meter (VTVM or DMM) for the negative grid check. It will probably de-tune the oscillator, but don't worry about that just now. If the grid stays negative throughout the tuning range, and is working on all bands, then start looking at the RF stage. It might be letting strong stations thru a bad coil, but that's all.
Keep us posted,
Al
::Along with replacing all of the paper caps, check for a negative voltage at pin 4 of the 6SA7. If not negative, then the oscillator is cutting out.
:::Check for drifted resistors in all of the circuitry involving this tube. Check for a weak/gassy tube. Check the tuning capacitor for shorts/dirt in both gangs, though if it works in a certain area for one band, but not for the other, then it is not likely the cause of your trouble.
:The fact that you are getting any stations at all pretty well eliminates the IF section of the radio, so concentrate on the RF and converter stages, especially the antenna and oscillator coils. Use a high impedance meter (VTVM or DMM) for the negative grid check. It will probably de-tune the oscillator, but don't worry about that just now. If the grid stays negative throughout the tuning range, and is working on all bands, then start looking at the RF stage. It might be letting strong stations thru a bad coil, but that's all.
:Keep us posted,
:Lewis
:Lewis
As far as resistance itself, % deviation depends on the circuit. Until you are familiar with the needs of various circuits, it is best at this point to just stick to original valves.
Play Things of the Past is also good.
