You can find lists for police and fire frequencies, and possibly some local to you, however you usually have to find them with search engines. You might even try just entering "K-100" into the search to see if someone might happen to have a manual for another Regency of that vintage. Most will program the same, and Uniden pretty much bought up the relevent patents that Regency and Bearcat held. There is a remote possibility that Uniden may have some archive for those, but it is doubtful.
: Was given this scanner. Had been unplugged for over year and when turned on, every channel shows 47.500 frequency. Tried pushing "manual"; go to channel 1; punch in desired frequency; push "enter"; then put to scan. Channel 1 again shows 47.500. I have no manual for this, nor do I know where I can obtain a manual. Can anyone help with this?
BTW, an aside for the newer sanners- The "modern" Radio Shack/Uniden (and I would suspect Relm, and other too), do not require a special program to connect- they use the built in (bundled) Telnet program of Windows from XP down to 3.0.
You may need to utilize a gender changer at times, but it is essentially a DB9 Serial port. Their instructions are quite simple, and quite clear in the manuals. Radio Shack does support their Scanners, and have manuals online for no cost to you.
::Was given this scanner. Had been unplugged for over year and when turned on, every channel shows 47.500 frequency. Tried pushing "manual"; go to channel 1; punch in desired frequency; push "enter"; then put to scan. Channel 1 again shows 47.500. I have no manual for this, nor do I know where I can obtain a manual. Can anyone help with this?
:is this scanner programmable by hooking the scanner up to a computer with the software from radio shack , they do have a program with conection cable for doing this trick and u should be able to program the scanner this way . something to look into
To john mcpherson,
You werent very far off at all. I have a K100 and I programed it by going to the desired channel, putting in the frequency, and then selected the next channel. That works for me. Hopefully it will work for you
THANKS I TOO WAS JUST GIVEN THIS UNIT AND COULD NOT PROGRAM IT!!!
