CORRECT VOLTAGE DROPPING RESISTORS needed
12/17/2012 6:49:00 PMchip
I am replacing 2 selenium rectifiers with a 1N4007 silicon diode. First 2 in series rectifiers - .630A (federal 1267A) and second 2 in series .540adc (federal 1319A) and need the correct voltage dropping resistor to use in each application?
12/17/2012 7:57:46 PMDoug Criner
I would just install the replacement diodes, and see how the voltages wind up. If the are much out of whack, then add the necessary resistor.
12/17/2012 7:59:41 PMDoug Criner
It totally depends upon the current, which we can't tell from your post. So, just put in the diodes, and monitor voltages.
12/18/2012 12:44:36 AMThomas Dermody
The only voltages that are really critical in most radios are filament voltages, especially for battery type tubes. Otherwise the B voltage is very non-critical, except perhaps with fixed bias tubes. Self-bias and grid-leak circuits are non-critical of B voltage.
The resistor will, however, help reduce hum. 50-100 ohms is fairly adequate.
12/18/2012 11:26:04 AMRich, W3HWJ
The short answer is: start with a 100 ohm resistor in series. Measure the B+ voltage. Choose another resistor if the voltage is above or below the mfr. spec.
Maybe this helps?
http://w3hwj.com/index_files/RBSelenium2.pdf
Make sure the resistor wattage is at least twice what you calculate. I like resistors to run cooler.
Rich
:The only voltages that are really critical in most radios are filament voltages, especially for battery type tubes. Otherwise the B voltage is very non-critical, except perhaps with fixed bias tubes. Self-bias and grid-leak circuits are non-critical of B voltage.
:The resistor will, however, help reduce hum. 50-100 ohms is fairly adequate.
