Delco radio
11/27/2012 1:39:32 PMRalph Schneider
I am working on a Delco car radio, it is AM only with a 8 track player, problem is the tag with the service ref # and SN# was torn off, I only have the modle # to go by it is 7939071, that modle is listed in 3 different Sam's, is ther any other way to id this radio?
11/27/2012 7:31:22 PMMAG
:I am working on a Delco car radio, it is AM only with a 8 track player, problem is the tag with the service ref # and SN# was torn off, I only have the modle # to go by it is 7939071, that modle is listed in 3 different Sam's, is ther any other way to id this radio?
Ralph,
The model number is ALWAYS the part of the tag that is torn or missing!
We would need more to go on to positively id the radio. 7939071 is GM’s product code for several years of AM radio/8 track tape players for Chevrolet cars and trucks. It crosses to model numbers 41BPBT1 (1974, found in Sams AR-166), 51BPBT1/2 (1975, in AR-188), 51BPBT3 (1975, in AR-207), 61BPBT1 (1976, also in AR-207), 61BPBT2 (1976, in AR-256), 71APBT1 (1977, not listed in Sams, but I have it in Delco 6D-1977-1).
You may be able to ID it from the number on the printed circuit board: D8M628 (41BPBT1), D8S628 (51BPBT1/2), D9A219 (51BPBT3, and 71APBT1) . I don’t have numbers for the others.
Meade
11/27/2012 8:34:50 PMRalph
::I am working on a Delco car radio, it is AM only with a 8 track player, problem is the tag with the service ref # and SN# was torn off, I only have the modle # to go by it is 7939071, that modle is listed in 3 different Sam's, is ther any other way to id this radio?
:Ralph,
:The model number is ALWAYS the part of the tag that is torn or missing!
:We would need more to go on to positively id the radio. 7939071 is GM’s product code for several years of AM radio/8 track tape players for Chevrolet cars and trucks. It crosses to model numbers 41BPBT1 (1974, found in Sams AR-166), 51BPBT1/2 (1975, in AR-188), 51BPBT3 (1975, in AR-207), 61BPBT1 (1976, also in AR-207), 61BPBT2 (1976, in AR-256), 71APBT1 (1977, not listed in Sams, but I have it in Delco 6D-1977-1).
:You may be able to ID it from the number on the printed circuit board: D8M628 (41BPBT1), D8S628 (51BPBT1/2), D9A219 (51BPBT3, and 71APBT1) . I don’t have numbers for the others. The circuit board has D9C219 stamped on it Does that help you? Ralph.
:Meade
11/27/2012 11:50:38 PMMAG
:::I am working on a Delco car radio, it is AM only with a 8 track player, problem is the tag with the service ref # and SN# was torn off, I only have the modle # to go by it is 7939071, that modle is listed in 3 different Sam's, is ther any other way to id this radio?
::Ralph,
::The model number is ALWAYS the part of the tag that is torn or missing!
::We would need more to go on to positively id the radio. 7939071 is GM’s product code for several years of AM radio/8 track tape players for Chevrolet cars and trucks. It crosses to model numbers 41BPBT1 (1974, found in Sams AR-166), 51BPBT1/2 (1975, in AR-188), 51BPBT3 (1975, in AR-207), 61BPBT1 (1976, also in AR-207), 61BPBT2 (1976, in AR-256), 71APBT1 (1977, not listed in Sams, but I have it in Delco 6D-1977-1).
::You may be able to ID it from the number on the printed circuit board: D8M628 (41BPBT1), D8S628 (51BPBT1/2), D9A219 (51BPBT3, and 71APBT1) . I don’t have numbers for the others.
Meade
Ralph,
1976 Chevrolet, Chevelle, Monte Carlo, and truck radio/tape model 61BPBT2. Your radio and also Buick, Olds, and Pontiac 1976 GM AM/Tape models are covered in AR-256.
Meade
11/28/2012 4:00:40 PMRalph
::::I am working on a Delco car radio, it is AM only with a 8 track player, problem is the tag with the service ref # and SN# was torn off, I only have the modle # to go by it is 7939071, that modle is listed in 3 different Sam's, is ther any other way to id this radio?
:::Ralph,
:::The model number is ALWAYS the part of the tag that is torn or missing!
:::We would need more to go on to positively id the radio. 7939071 is GM’s product code for several years of AM radio/8 track tape players for Chevrolet cars and trucks. It crosses to model numbers 41BPBT1 (1974, found in Sams AR-166), 51BPBT1/2 (1975, in AR-188), 51BPBT3 (1975, in AR-207), 61BPBT1 (1976, also in AR-207), 61BPBT2 (1976, in AR-256), 71APBT1 (1977, not listed in Sams, but I have it in Delco 6D-1977-1).
:::You may be able to ID it from the number on the printed circuit board: D8M628 (41BPBT1), D8S628 (51BPBT1/2), D9A219 (51BPBT3, and 71APBT1) . I don’t have numbers for the others.
:Meade
: The circuit board has D9C219 stamped on it Does that help you? Ralph.
:Ralph,
:1976 Chevrolet, Chevelle, Monte Carlo, and truck radio/tape model 61BPBT2. Your radio and also Buick, Olds, and Pontiac 1976 GM AM/Tape models are covered in AR-256.
:Meade
Thank you for your help, I will put that modle # on the case with a permanet marker, Ralph
