11/27/2012 12:08:23 PMlouis c freschlin(103441:0)
I have a Zenith radio (1949) Model G725 Ch=7G01. The socket that holds the dial light has broken wires. How can I get a new socket & schematic to rewire it? The radio works great, but no light.
11/27/2012 1:55:01 PMNorm Leal(103445:103441)
Hi Louis
Check AES, www.tubesandmore.com . Item number P-L101 and P-L104.
:I have a Zenith radio (1949) Model G725 Ch=7G01. The socket that holds the dial light has broken wires. How can I get a new socket & schematic to rewire it? The radio works great, but no light.
11/27/2012 2:40:07 PMThomas Dermody(103446:103445)
Often, if you are able to carefully disassemble the socket, you can solder new wires to the existing socket. There are many different socket designs. However, I have yet to run across a socket that I could not fit with new wires.
11/29/2012 3:41:11 PMlouis c freschlin(103477:103446)
:Often, if you are able to carefully disassemble the socket, you can solder new wires to the existing socket. There are many different socket designs. However, I have yet to run across a socket that I could not fit with new wires.
:T.
:Thanks for the info. Lou
12/1/2012 1:36:24 PMRaymond(103516:103441)
:The wires are easy to repair.Strip,splice & solder, then use shrink tubing over the splice. Raymond.
