11/23/2012 7:51:31 PMElton(103355:0)
I had a open shadow coil , so I carefully tore in to it and found the break... was only a few turns in, now my question is how do I terminate the wires of the coil back to larger wire? I have tried to tin the ends of the coil wire but is so thin. Any ideas on how to do this so I have a stable connection?
E.
11/23/2012 8:43:37 PMThomas Dermody(103358:103355)
If there is enough wire, I wind a few turns around the wire I wish to solder it to. Then heat the junction well to burn off the enamel, and saturate with solder.
11/29/2012 3:37:37 PMRaymond(103473:103358)
:If there is enough wire, I wind a few turns around the wire I wish to solder it to. Then heat the junction well to burn off the enamel, and saturate with solder.
:Thats how I fix broken wires on i.f. transformers. Be VERY,VERY careful & use a pair of reading glasses 2.5 power or higher. Another thing you can try is an eye loop avaliale at jeweler stores. Sometimes I use one when I ABSOLUTELY have to, they are rather clumsy!! Take care now. Raymond.
11/29/2012 3:37:38 PMRaymond(103474:103358)
