GE L916
11/14/2012 7:25:13 PMdavid
Hi every one I have a new project and I am not sure what to do with I would like to make it play again.There is two tubes missing and the power transformerhas been replaced with one that does not fit the holes to mount it,some one soldered it to the chassic and it has come loose the wires are wired together and taped up with tape there is two loose wiresall that I have done is cleaned it up a bit and looked over is there any way to get a transfomer and instructions on hooking it up, any coments would be welcom. David
11/14/2012 7:59:55 PMMitch
:Hi every one I have a new project and I am not sure what to do with I would like to make it play again.There is two tubes missing and the power transformerhas been replaced with one that does not fit the holes to mount it,some one soldered it to the chassic and it has come loose the wires are wired together and taped up with tape there is two loose wiresall that I have done is cleaned it up a bit and looked over is there any way to get a transfomer and instructions on hooking it up, any coments would be welcom. David
This may help,
http://www.nostalgiaair.org/PagesByModel/199/M0008199.pdf
Mitch
11/14/2012 9:57:12 PMdavid
::Hi every one I have a new project and I am not sure what to do with I would like to make it play again.There is two tubes missing and the power transformerhas been replaced with one that does not fit the holes to mount it,some one soldered it to the chassic and it has come loose the wires are wired together and taped up with tape there is two loose wiresall that I have done is cleaned it up a bit and looked over is there any way to get a transfomer and instructions on hooking it up, any coments would be welcom. David
:This may help,
:http://www.nostalgiaair.org/PagesByModel/199/M0008199.pdf
:Mitch I had trouble getting the web site but i GOOGLE IT AND ONLY GOT A SECMATIC THAT I HAD JUST ENLARGED BUT I COULD NOT PRINT IT OUT.
:Mitch
11/14/2012 11:08:34 PMMitch
:::Hi every one I have a new project and I am not sure what to do with I would like to make it play again.There is two tubes missing and the power transformerhas been replaced with one that does not fit the holes to mount it,some one soldered it to the chassic and it has come loose the wires are wired together and taped up with tape there is two loose wiresall that I have done is cleaned it up a bit and looked over is there any way to get a transfomer and instructions on hooking it up, any coments would be welcom. David
::This may help,
::http://www.nostalgiaair.org/PagesByModel/199/M0008199.pdf
::Mitch I had trouble getting the web site but i GOOGLE IT AND ONLY GOT A SECMATIC THAT I HAD JUST ENLARGED BUT I COULD NOT PRINT IT OUT.
::Mitch
Try this,
Mitch
