:Yep when the volume is all the way up. maybe I'm just getting picky.
::Yep when the volume is all the way up. maybe I'm just getting picky.
If you are not obtaining this without significant distortion, you should check your resistors for proper value (disconnected), check the output transformer for proper resistance (in case that there are shorts), and possibly check for weak/gassy tubes.
Resistors in the audio section can drift fairly high before affecting performance adversely. Increase in plate and grid resistors will add bass to the music, but at a certain point the amplifier will become weak.
The output cathode bias method is critical. If the bias between the cathode and the grid becomes too great, often due to a drifted resistor, maximum undistorted power output can drop. The bias keeps the grid operating in the linear range of tube conduction.
In my ventures for new and different career paths, and kind of interested in starting my own business, I decided to throw all of the services (clean) that I am capable of on Craigslist, and one of them was antique radio repair. The only response I got was for the antique radio repair from a guy south of me who sells guitar amplifiers, guitars, records, jukeboxes, and antique radios, and the first project I am working on for him is a Philco 81.
Sadly I think that I am charging way too little for labor, and think that I will have to adjust this as I go along. Thankfully I didn't quit my day job, and I certainly don't intend to.
The radio is recapped. I did it the quick way with exposed modern caps and binding posts, as it would not be profitable for either of us to restuff the bakelite blocks.
I was told that the radio worked 25 years ago, but was kinda weak, except if he touched the antenna cap. Well, after the recap, the radio actually did play quietly, and played much louder when I touched one of the grid caps. I forgot which one. At any rate, I probed around and found that the secondary of the 2nd detector coil was open. There was a tap drawn down within the coil that wasn't connected to any terminal, and both halves of this tap were disconnected to eachother, and so I soldered them together. The coil measures proper resistance now, but now the receiver is completely dead reception-wise. It actually starts to have static when it is first turned on, but that goes away after a second or two. I noticed that the 2nd detector plate and screen voltages are low. They are about 25 volts, and should be like 75 and 40 respectively. Couldn't find anything wrong in the circuit. Resistors are just fine. Swapped tubes and same thing. Voltage at grid and cathode are fine, and B+ is fine, too.
All coil resistances are fine. No trimmer shorts or anything.
Eh. I'm going to bed now. I wish I could charge the amount of time this is actually taking me. Boo.
The Tubes section isn't currently working, but I have my handy Tung Sol book to refer to. I'm just too lazy and would rather look data up here.
....of course what they don't tell you in the schematic (unless I just didn't read far enough) is that actually that top part of the winding (2nd detector secondary) is actually NOT supposed to connect to the rest of the coil. No resistance value is given. Considering that this is a detector, I was curious as to what detection method was being used. There was no indication of a very high cathode bias or exceptionally low plate voltage (well, 70 is kinda low, but not really), and no grid leak capacitor set-up. However, a clue that one does exist is that R19 is 4Meg.
...........and so I am going to disconnect the two wires that I soldered together and leave the very top portion of the winding disconnected from the rest. It will be connected by capacitance only.
Incidentally I also found one of the #77 tubes to be glowing purple inside, and so I have swapped it out for a good one. At this point there was no improvement, but hopefully with the coil set up as it should be, the set will perform well.
YAY!
:Sadly I just wind my coils by hand, but I don't wind that many coils. Lately the last coils I wound were for FM, and that doesn't take much doing. Would be nice to have a zig-zag winder.
:T.
