I have restored this radio and have been playing it to be sure it is working ok for the person who is going to buy it, it sounds good and picks up all of the stations where i live.
It is a low cost radio and has a tinny sound to it, although very clear on the small speaker. It does not have a tone control as seen by the schematic.
Some time ago Warren gave me a fix for this by installing a low voltage filter capacitor in the output of the radio that gave me a better, richer, tone to the output. I could experiment with the values until i got the sound that i wanted. Where would i install this capacitor?
Can some one tell me what this fix, modification, would be in the circuit of this radio (Warren, you are most welcome to post on this question as always)?
I would just like a better tone on the radio.
Most regards to all,
Mitch
I don't have a schematic, but if the coupling cap between the first and second (output) audio stages is a .01 uFd, you could try a .1, that might increase the bass a little.
It would seem that low cost is low cost, for this radio.
I did install a 22 MFD capacitor across R-9, it did give more gain. C-11 changes made no change. Cap on the input made no change.
It is a very small 3" speaker, even with a 6" sub it was still a little tinny.
You all know the Forum is great and thanks for the input.
The capacitor change did improve what i needed, more gain and a stronger sound on a basic radio.
Now, I will say that my night time radio that i listen to is a 1933 Philco that i restored and has the big radio sound, I MEAN BIG SOUND, so perhaps i am spoiled.
Thank you gentlemen,
Mitch
Suggestions mentioned are good for increasing low frequency response. You could try reducing high frequency response by adding capacity from the signal line to ground. This will have a similar effect as increasing low frequency response.
Most likely limiting factor is the speaker. Although you can't mount a larger speaker in this radio try connecting one.
http://www.nostalgiaair.org/PagesByModel/048/M0006048.pdf
:Hello everyone,
:I have restored this radio and have been playing it to be sure it is working ok for the person who is going to buy it, it sounds good and picks up all of the stations where i live.
:It is a low cost radio and has a tinny sound to it, although very clear on the small speaker. It does not have a tone control as seen by the schematic.
:Some time ago Warren gave me a fix for this by installing a low voltage filter capacitor in the output of the radio that gave me a better, richer, tone to the output. I could experiment with the values until i got the sound that i wanted. Where would i install this capacitor?
:Can some one tell me what this fix, modification, would be in the circuit of this radio (Warren, you are most welcome to post on this question as always)?
:I would just like a better tone on the radio.
:Most regards to all,
:Mitch
:Mitch
: Suggestions mentioned are good for increasing low frequency response. You could try reducing high frequency response by adding capacity from the signal line to ground. This will have a similar effect as increasing low frequency response.
: Most likely limiting factor is the speaker. Although you can't mount a larger speaker in this radio try connecting one.
:http://www.nostalgiaair.org/PagesByModel/048/M0006048.pdf
::Hello everyone,
::I have restored this radio and have been playing it to be sure it is working ok for the person who is going to buy it, it sounds good and picks up all of the stations where i live.
::It is a low cost radio and has a tinny sound to it, although very clear on the small speaker. It does not have a tone control as seen by the schematic.
::Some time ago Warren gave me a fix for this by installing a low voltage filter capacitor in the output of the radio that gave me a better, richer, tone to the output. I could experiment with the values until i got the sound that i wanted. Where would i install this capacitor?
::Can some one tell me what this fix, modification, would be in the circuit of this radio (Warren, you are most welcome to post on this question as always)?
::I would just like a better tone on the radio.
::Most regards to all,
::Mitch
