I use the ARBE-III for my battery radios, others make up their own battery packs.
Go here to see the ARBE-III
http://www.arbeiii.com/
Mitch
If you can find the resistance value inside the 1P1 you can sub in a resistor and still use three volts.
Mitch
I wonder if a couple 1.5 volt flashlight batts in series and in series with a silicon diode or two would work: 2.4/1.8 volts??
Clifton
:::i have a silvertone model 4423.it has 2 volt tubes,where can i find a battery elim.for 2 volt tubes
::Doug,
::I use the ARBE-III for my battery radios, others make up their own battery packs.
::Go here to see the ARBE-III
::http://www.arbeiii.com/
::Mitch
:If you have the 1P1 tube installed with the current limiter resistor you can us two 1.5 volt batteries in series for the 3 volt filament voltage, if you have the adapter you will need two volts.
:If you can find the resistance value inside the 1P1 you can sub in a resistor and still use three volts.
:Mitch
Tube filaments draw .36 amps. Using a 2.7 ohm series resistor with 3 volt battery will work.
http://www.nostalgiaair.org/PagesByModel/013/M0017013.pdf
:Mitch,
:I wonder if a couple 1.5 volt flashlight batts in series and in series with a silicon diode or two would work: 2.4/1.8 volts??
:Clifton
::::i have a silvertone model 4423.it has 2 volt tubes,where can i find a battery elim.for 2 volt tubes
:::Doug,
:::I use the ARBE-III for my battery radios, others make up their own battery packs.
:::Go here to see the ARBE-III
:::http://www.arbeiii.com/
:::Mitch
::If you have the 1P1 tube installed with the current limiter resistor you can us two 1.5 volt batteries in series for the 3 volt filament voltage, if you have the adapter you will need two volts.
::If you can find the resistance value inside the 1P1 you can sub in a resistor and still use three volts.
::Mitch
