EICO 666 Tube Data Correction Chart.
10/30/2012 4:25:06 PMBob Masse
:http://sdrv.ms/Svk9uc
Hi!
If you copy and paste the above link it will take you to a copy of a Tube Data Correction Chart for the Eico 666 tube tester.
Bob Masse
10/30/2012 10:18:07 PMBob Masse
::http://sdrv.ms/Svk9uc
:Hi!
:If you copy and paste the above link it will take you to a copy of a Tube Data Correction Chart for the Eico 666 tube tester.
:Bob Masse
:It is also available at :
http://www.ebaman.com/index.php/remository/func-startdown/22199/
:Bob Masse
10/31/2012 7:03:38 PMCAUTION!!
:::http://sdrv.ms/Svk9uc
::Hi!
::If you copy and paste the above link it will take you to a copy of a Tube Data Correction Chart for the Eico 666 tube tester.
::Bob Masse
::It is also available at :
:http://www.ebaman.com/index.php/remository/func-startdown/22199/
::Bob Masse
:CAUTION!!! I've now been told that the correction chart is full of errors!!!!
Bob Masse
11/26/2012 3:00:09 PMRaymond
::::http://sdrv.ms/Svk9uc
:::Hi!
:::If you copy and paste the above link it will take you to a copy of a Tube Data Correction Chart for the Eico 666 tube tester.
:::Bob Masse
:::It is also available at :
::http://www.ebaman.com/index.php/remository/func-startdown/22199/
:::Bob Masse
::CAUTION!!! I've now been told that the correction chart is full of errors!!!!
:Bob Masse
:;Sounds like EICO! Mine has error's also on the main roll chart. Some are obvious! & some are questionable.
