BOP
10/23/2012 10:05:34 AMSandy Jones
Newbie here-
I have a 1933 Buick " limo" that has a BOP radio, 980393, Super Heterodyne in it. Was installed June 6, 1933.
The radio head is mounted in the center of the dash and is a locking type with key. It turns on, lights up. I took the cover off the radio and nothing lights up inside or no vibrator noise. This is a three part radio, mounted head, large round speaker and radio box. ( sorry about terms )
Radio is very clean, appears original.
My question here: I was thinking of getting it to work, if it's something straight forward like replacing tubes or vibrator etc. I'm reluctant to remove it as this is a original car and it's mounted somehow from behind, on the firewall.
OK, what do you guys think about attacking this project, or just leave alone. I just don't want to tear anything up on the car to do a fun project.(winter project ?)
Sandy Jones
10/23/2012 10:49:10 AMEzblah
Sandy,
Very cool indeed! If you are an old car guy then you may already know that most of your fellow car guys send their radios off to one of the places found in magazines or on-line and have a solid state module placed inside the radio. It uses the original radio dial and provides FM as well as AM. Never used one, but I hear the results are less than ideal, which is odd, since they charge way more than necessary. The radios get this treatment since most old radio repair guys don't like repairing old car radios. Typically the sets are in horrible shape and can be hard to fix. Your radio sounds like it can (and should) be saved. It will have to be removed (along with control head and speaker) from the car and presented to someone for evaluation and an estimate. It is not just a matter of tubes and vibrator replacement. But since it is in good condition, like the auto, and not abused, you stand a good chance of finding someone in your area to tackle the job. Best of luck.
10/23/2012 11:01:55 AMSandy Jones
:Sandy,
:Very cool indeed! If you are an old car guy then you may already know that most of your fellow car guys send their radios off to one of the places found in magazines or on-line and have a solid state module placed inside the radio. It uses the original radio dial and provides FM as well as AM. Never used one, but I hear the results are less than ideal, which is odd, since they charge way more than necessary. The radios get this treatment since most old radio repair guys don't like repairing old car radios. Typically the sets are in horrible shape and can be hard to fix. Your radio sounds like it can (and should) be saved. It will have to be removed (along with control head and speaker) from the car and presented to someone for evaluation and an estimate. It is not just a matter of tubes and vibrator replacement. But since it is in good condition, like the auto, and not abused, you stand a good chance of finding someone in your area to tackle the job. Best of luck.
Thanks- I will not replace the inside, it must stay original, working or not. I, of course, was hoping for an easy fix. Haaaaa. I see a Sylvania tube in there and a little brown like capacitor with three round colors, as if it's been repaired at some time. ?
Appreciare the response, I've had a radio redone in a 34 Ford years ago.
\SJ
10/23/2012 10:54:19 AMJohn K
There is a picture of your control unit here.
https://www.sites.google.com/site/identifyinginstrumentpanels/home/radios-index/radios-buick-page-1
It sounds like you have power to the dial lamp, but no power to the tubes? There is not much you can do without removing the radio from the car first. Even if the radio was operational, it needs new capacitors installed or else it would be in danger of shorting out and catching fire. No kidding, it could easily start a fire under the dashboard.
:Newbie here-
:I have a 1933 Buick " limo" that has a BOP radio, 980393, Super Heterodyne in it. Was installed June 6, 1933.
:The radio head is mounted in the center of the dash and is a locking type with key. It turns on, lights up.
10/23/2012 11:04:27 AMSandy Jones
:There is a picture of your control unit here.
:https://www.sites.google.com/site/identifyinginstrumentpanels/home/radios-index/radios-buick-page-1
:It sounds like you have power to the dial lamp, but no power to the tubes? There is not much you can do without removing the radio from the car first. Even if the radio was operational, it needs new capacitors installed or else it would be in danger of shorting out and catching fire. No kidding, it could easily start a fire under the dashboard.
::Newbie here-
::I have a 1933 Buick " limo" that has a BOP radio, 980393, Super Heterodyne in it. Was installed June 6, 1933.
::The radio head is mounted in the center of the dash and is a locking type with key. It turns on, lights up.
Thanks guys, I'll probably leave well enough alone. John, yes you are correct, thanks.
SJ
10/23/2012 11:16:47 AMSandy Jones
::There is a picture of your control unit here.
::https://www.sites.google.com/site/identifyinginstrumentpanels/home/radios-index/radios-buick-page-1
::It sounds like you have power to the dial lamp, but no power to the tubes? There is not much you can do without removing the radio from the car first. Even if the radio was operational, it needs new capacitors installed or else it would be in danger of shorting out and catching fire. No kidding, it could easily start a fire under the dashboard.
:::Newbie here-
:::I have a 1933 Buick " limo" that has a BOP radio, 980393, Super Heterodyne in it. Was installed June 6, 1933.
:::The radio head is mounted in the center of the dash and is a locking type with key. It turns on, lights up.
:Thanks guys, I'll probably leave well enough alone. John, yes you are correct, thanks.
:SJ
I opened the link showing control units- I have a 1932 radio installed in my Buick 90. As posted before, it was installed in June, 1933 and signed.
This is not unusual, they installed what was on the shelf, as this was an early production car. Buick just about went under in 1933, so were using everything they had to stay alive. This car was originally owned by the DuPont family,that owned 30% of GM.
Wonderful information, about the radio-
Many thanks !!!
Sandy
10/23/2012 3:02:01 PMLewis L.
:::There is a picture of your control unit here.
:::https://www.sites.google.com/site/identifyinginstrumentpanels/home/radios-index/radios-buick-page-1
:::It sounds like you have power to the dial lamp, but no power to the tubes? There is not much you can do without removing the radio from the car first. Even if the radio was operational, it needs new capacitors installed or else it would be in danger of shorting out and catching fire. No kidding, it could easily start a fire under the dashboard.
::::Newbie here-
::::I have a 1933 Buick " limo" that has a BOP radio, 980393, Super Heterodyne in it. Was installed June 6, 1933.
::::The radio head is mounted in the center of the dash and is a locking type with key. It turns on, lights up.
::Thanks guys, I'll probably leave well enough alone. John, yes you are correct, thanks.
::SJ
:I opened the link showing control units- I have a 1932 radio installed in my Buick 90. As posted before, it was installed in June, 1933 and signed.
:This is not unusual, they installed what was on the shelf, as this was an early production car. Buick just about went under in 1933, so were using everything they had to stay alive. This car was originally owned by the DuPont family,that owned 30% of GM.
:Wonderful information, about the radio-
:Many thanks !!!
:Sandy
Sandy:
The schematic and lots of info is on this site. Before you decide to "leave well enough alone", why don't you at least try to learn more about it? There is plenty of experience here, and a non-working radio is painful to most of us, we will give plenty of help. Besides, wouldn't a working radio in a 1933 car be cool?
10/25/2012 9:44:08 AMSandy
::::There is a picture of your control unit here.
::::https://www.sites.google.com/site/identifyinginstrumentpanels/home/radios-index/radios-buick-page-1
::::It sounds like you have power to the dial lamp, but no power to the tubes? There is not much you can do without removing the radio from the car first. Even if the radio was operational, it needs new capacitors installed or else it would be in danger of shorting out and catching fire. No kidding, it could easily start a fire under the dashboard.
:::::Newbie here-
:::::I have a 1933 Buick " limo" that has a BOP radio, 980393, Super Heterodyne in it. Was installed June 6, 1933.
:::::The radio head is mounted in the center of the dash and is a locking type with key. It turns on, lights up.
:::Thanks guys, I'll probably leave well enough alone. John, yes you are correct, thanks.
:::SJ
::I opened the link showing control units- I have a 1932 radio installed in my Buick 90. As posted before, it was installed in June, 1933 and signed.
::This is not unusual, they installed what was on the shelf, as this was an early production car. Buick just about went under in 1933, so were using everything they had to stay alive. This car was originally owned by the DuPont family,that owned 30% of GM.
::Wonderful information, about the radio-
::Many thanks !!!
::Sandy
:Sandy:
:The schematic and lots of info is on this site. Before you decide to "leave well enough alone", why don't you at least try to learn more about it? There is plenty of experience here, and a non-working radio is painful to most of us, we will give plenty of help. Besides, wouldn't a working radio in a 1933 car be cool?
:Lewis
Hi Lewis, thanks-
Two problems a) removing the radio without damage to the originality of the car Any break in the paint or such is not good. Also the wires are 1933 original, good shape it appears, but old.
b) The Am stations are a bit iffy to listen too, actually real iffy.
I restore cars as a hobby, been doing this all my life. I guess that's why I asked if it could be a simple change in a tube, I didn't know. I love learning this stuff, but uf you saw the car you may understand. There are only two of these 1933 original Buick 90s that we know of, I owned both, just sold one.
Thanks for the comment-
Sandy
10/25/2012 11:21:45 AMLewis L.
:::::There is a picture of your control unit here.
:::::https://www.sites.google.com/site/identifyinginstrumentpanels/home/radios-index/radios-buick-page-1
:::::It sounds like you have power to the dial lamp, but no power to the tubes? There is not much you can do without removing the radio from the car first. Even if the radio was operational, it needs new capacitors installed or else it would be in danger of shorting out and catching fire. No kidding, it could easily start a fire under the dashboard.
::::::Newbie here-
::::::I have a 1933 Buick " limo" that has a BOP radio, 980393, Super Heterodyne in it. Was installed June 6, 1933.
::::::The radio head is mounted in the center of the dash and is a locking type with key. It turns on, lights up.
::::Thanks guys, I'll probably leave well enough alone. John, yes you are correct, thanks.
::::SJ
:::I opened the link showing control units- I have a 1932 radio installed in my Buick 90. As posted before, it was installed in June, 1933 and signed.
:::This is not unusual, they installed what was on the shelf, as this was an early production car. Buick just about went under in 1933, so were using everything they had to stay alive. This car was originally owned by the DuPont family,that owned 30% of GM.
:::Wonderful information, about the radio-
:::Many thanks !!!
:::Sandy
::Sandy:
::The schematic and lots of info is on this site. Before you decide to "leave well enough alone", why don't you at least try to learn more about it? There is plenty of experience here, and a non-working radio is painful to most of us, we will give plenty of help. Besides, wouldn't a working radio in a 1933 car be cool?
::Lewis
:Hi Lewis, thanks-
:Two problems a) removing the radio without damage to the originality of the car Any break in the paint or such is not good. Also the wires are 1933 original, good shape it appears, but old.
:b) The Am stations are a bit iffy to listen too, actually real iffy.
:I restore cars as a hobby, been doing this all my life. I guess that's why I asked if it could be a simple change in a tube, I didn't know. I love learning this stuff, but uf you saw the car you may understand. There are only two of these 1933 original Buick 90s that we know of, I owned both, just sold one.
:Thanks for the comment-
:Sandy
Sandy:
You are talking with someone retired after a thirty five year career with an airline...no airplane EVER left home (Atlanta) with a defective radio on board...I drive my wife crazy overhauling things around the house, too.
10/28/2012 12:07:12 PMSandy
Haaaaaaaaaaaaaaaa, I learned to fly in a 1945 J-3 Piper Cub, as my father did.
This plane ALWAYS left home with a defective radio. There wasn't any.
I drive my wife crazy too, just in general.
SJ
:Sandy:
:You are talking with someone retired after a thirty five year career with an airline...no airplane EVER left home (Atlanta) with a defective radio on board...I drive my wife crazy overhauling things around the house, too.
:Lewis
10/25/2012 11:20:34 PMJohn K
:Hi Lewis, thanks-
:Sandy
If you want to take a stab at making the radio play in the car, you could try replacing the rectifier tube. If the filament in one tube burns out, none of the tubes will light up. The rectifier is vulnerable. But I don't know that radio.
The vibrator can be taken out and cleaned and tested.
The capacitors will still be dried out and prone to burning up, but they can be reformed somewhat by bringing voltage up slowly. In this case, you have 6 volt power, so you would need to learn how to do this from someone other than me. :>)
Then you could say the radio works, but there is nothing on.
10/26/2012 4:27:38 AMLou
Sandy:
Along those lines, if you could just disconnect the radio 6 volt power lead, then you could use an external power supply to bring it up slowly. You probably will need a few amps to run it at least.
That way you will not get an immediate failure on power up.
Lou
::Hi Lewis, thanks-
::Two problems a) removing the radio without damage to the originality of the car Any break in the paint or such is not good. Also the wires are 1933 original, good shape it appears, but old.
::b) The Am stations are a bit iffy to listen too, actually real iffy.
::I restore cars as a hobby, been doing this all my life. I guess that's why I asked if it could be a simple change in a tube, I didn't know. I love learning this stuff, but uf you saw the car you may understand. There are only two of these 1933 original Buick 90s that we know of, I owned both, just sold one.
::Thanks for the comment-
::Sandy
:If you want to take a stab at making the radio play in the car, you could try replacing the rectifier tube. If the filament in one tube burns out, none of the tubes will light up. The rectifier is vulnerable. But I don't know that radio.
:The vibrator can be taken out and cleaned and tested.
:The capacitors will still be dried out and prone to burning up, but they can be reformed somewhat by bringing voltage up slowly. In this case, you have 6 volt power, so you would need to learn how to do this from someone other than me. :>)
:Then you could say the radio works, but there is nothing on.
10/26/2012 11:09:52 AMDavidP
I have a 6 volt vibrator if you need one.
:Sandy:
:Along those lines, if you could just disconnect the radio 6 volt power lead, then you could use an external power supply to bring it up slowly. You probably will need a few amps to run it at least.
:That way you will not get an immediate failure on power up.
:Lou
:::Hi Lewis, thanks-
:::Two problems a) removing the radio without damage to the originality of the car Any break in the paint or such is not good. Also the wires are 1933 original, good shape it appears, but old.
:::b) The Am stations are a bit iffy to listen too, actually real iffy.
:::I restore cars as a hobby, been doing this all my life. I guess that's why I asked if it could be a simple change in a tube, I didn't know. I love learning this stuff, but uf you saw the car you may understand. There are only two of these 1933 original Buick 90s that we know of, I owned both, just sold one.
:::Thanks for the comment-
:::Sandy
::If you want to take a stab at making the radio play in the car, you could try replacing the rectifier tube. If the filament in one tube burns out, none of the tubes will light up. The rectifier is vulnerable. But I don't know that radio.
::The vibrator can be taken out and cleaned and tested.
::The capacitors will still be dried out and prone to burning up, but they can be reformed somewhat by bringing voltage up slowly. In this case, you have 6 volt power, so you would need to learn how to do this from someone other than me. :>)
::Then you could say the radio works, but there is nothing on.
10/26/2012 4:04:26 PMJohn K
There is a schematic and some diagnostic tips here under Resources/Buick Motor.
This appears to have been the very first model made specifically for this car. Pre 1933, car radio was a novelty. Google 'Motorola' for more of that story.
It looks like the 84 rectifier tube is in a power supply module separate from the radio proper. That is, I don't see the rectifier in the main chassis. I would start with voltage checks in that area.
10/28/2012 12:20:38 PMSandy
John I think you opened up a thought here- i.e. power supply module. The car has a central power supply board, where the hot lead comes in, it's called the current limit relay. Everything feeds off that. This is a 1933 version of a circuit breaker or fuse. If something goes bad this thing hums to let you know there is trouble.
Anyway, connected on one side is a black cylinder about the size of my little finger. I had/have no clue what it's for, it was disconnected on one end. This may be the power supply module. Looking at the tubes, I can see no round metal casing type tube as a vibrator looks, or what I think it looks like, just the glass tubes-
See, now you guys got me going !!!!!!!!! Haaaaaaaaaaa
b intouch
Sandy
:There is a schematic and some diagnostic tips here under Resources/Buick Motor.
:This appears to have been the very first model made specifically for this car. Pre 1933, car radio was a novelty. Google 'Motorola' for more of that story.
:It looks like the 84 rectifier tube is in a power supply module separate from the radio proper. That is, I don't see the rectifier in the main chassis. I would start with voltage checks in that area.
10/28/2012 12:38:50 PMSandy
Another odd thing, the radio is installed upside down, I think. All the tubes are upside down, is this correct ? I'm fairly sure that's how it was installed in 1933, at least the sticker inside is signed off by someone in 1933.
:John I think you opened up a thought here- i.e. power supply module. The car has a central power supply board, where the hot lead comes in, it's called the current limit relay. Everything feeds off that. This is a 1933 version of a circuit breaker or fuse. If something goes bad this thing hums to let you know there is trouble.
:Anyway, connected on one side is a black cylinder about the size of my little finger. I had/have no clue what it's for, it was disconnected on one end. This may be the power supply module. Looking at the tubes, I can see no round metal casing type tube as a vibrator looks, or what I think it looks like, just the glass tubes-
:See, now you guys got me going !!!!!!!!! Haaaaaaaaaaa
:b intouch
:Sandy
::There is a schematic and some diagnostic tips here under Resources/Buick Motor.
::This appears to have been the very first model made specifically for this car. Pre 1933, car radio was a novelty. Google 'Motorola' for more of that story.
::It looks like the 84 rectifier tube is in a power supply module separate from the radio proper. That is, I don't see the rectifier in the main chassis. I would start with voltage checks in that area.
10/28/2012 12:59:20 PMeasyrider8
There is a lot of incorrect information posted here, following it can cause serious damage to your radio.
Do not attempt to power it up. Remove the radio and have it restored by someone who knows how to repair these radios.
There are many parts which will have to be replaced before power can be applied.
10/28/2012 1:37:02 PMLewis L.
:There is a lot of incorrect information posted here, following it can cause serious damage to your radio.
:Do not attempt to power it up. Remove the radio and have it restored by someone who knows how to repair these radios.
:There are many parts which will have to be replaced before power can be applied.
:Dave
Dave:
I think he doesn't want risk putting a scratch on the car removing the radio, just to listen to AM. He is a car nut. We are radio nuts. He sees a one-of-a-kind priceless antique Buick in mint condition. We see a broken radio that we can fix. And some think radio people are kind of strange at times.
10/28/2012 11:30:13 PMJohn K
Upside down is fine. Car radio tubes were designed to take a fair bit of abuse.
The small cylinder may be a condensor or capacitor to cut radio interference. Newer vehicles had them on the generator and the distributor. There were no mini electronics in 1933, so the power module for the radio I expect is about the size of a pound of butter with a tube and a vibrator in it.
6 volts DC is bumped up to over 100 volts AC by the vibrating points. Then the rectifier tube converts that to DC to provide power to the plates of the tubes in the radio proper.
The tube filaments in the main radio probably operate on 6 volts from the car battery. The dial lamp has power, so look beyond that for a bad connection.
Dave is correct of course. We all want you to have the radio taken out and rebuilt. Even if you got the power supply sorted out, the quality of operation would be disappointing, if it keeps working at all.
10/30/2012 9:54:45 AMLewis L.
:Upside down is fine. Car radio tubes were designed to take a fair bit of abuse.
:The small cylinder may be a condensor or capacitor to cut radio interference. Newer vehicles had them on the generator and the distributor. There were no mini electronics in 1933, so the power module for the radio I expect is about the size of a pound of butter with a tube and a vibrator in it.
:6 volts DC is bumped up to over 100 volts AC by the vibrating points. Then the rectifier tube converts that to DC to provide power to the plates of the tubes in the radio proper.
:The tube filaments in the main radio probably operate on 6 volts from the car battery. The dial lamp has power, so look beyond that for a bad connection.
:Dave is correct of course. We all want you to have the radio taken out and rebuilt. Even if you got the power supply sorted out, the quality of operation would be disappointing, if it keeps working at all.
Sandy:
If you are concerned about the lack of anything good on AM, a lot of the guys that rebuild old AM radios here build a small AM transmitter and play music from whatever source with no connection whatsoever to the antique radio. You could have your car playing music from the thirties and WWII, say Glenn Miller or Duke Ellington coming from a little portable box sitting on the seat next to you, or in the back seat, received just like a radio station. To me, THAT would be cool!
11/6/2012 10:20:44 AMsandy
Lewis-
Was thinking of something like that, a small CD player that could be stuck up behind the dash, so when you turned the radio on, it lit the dial head up but was not connected to the radio and the CD player would start. The station selector of course wouldn't work either, just turn. They Walmart etc. have these little CD players that have two tiny speakers, which could also be mounted with something, all hidden.
::Upside down is fine. Car radio tubes were designed to take a fair bit of abuse.
::The small cylinder may be a condensor or capacitor to cut radio interference. Newer vehicles had them on the generator and the distributor. There were no mini electronics in 1933, so the power module for the radio I expect is about the size of a pound of butter with a tube and a vibrator in it.
::6 volts DC is bumped up to over 100 volts AC by the vibrating points. Then the rectifier tube converts that to DC to provide power to the plates of the tubes in the radio proper.
::The tube filaments in the main radio probably operate on 6 volts from the car battery. The dial lamp has power, so look beyond that for a bad connection.
::Dave is correct of course. We all want you to have the radio taken out and rebuilt. Even if you got the power supply sorted out, the quality of operation would be disappointing, if it keeps working at all.
:Sandy:
:If you are concerned about the lack of anything good on AM, a lot of the guys that rebuild old AM radios here build a small AM transmitter and play music from whatever source with no connection whatsoever to the antique radio. You could have your car playing music from the thirties and WWII, say Glenn Miller or Duke Ellington coming from a little portable box sitting on the seat next to you, or in the back seat, received just like a radio station. To me, THAT would be cool!
:Lewis
11/10/2012 7:57:58 PMSandy
This may not be as difficult as I think, to remove it, the original one. Was talking to another fellow, that has a similar car 1933, and has one restored.
But this is a restoration, mine is original. My clue is, the speaker face is turned toward the firewall, never knew that- Progress.
:Lewis-
:Was thinking of something like that, a small CD player that could be stuck up behind the dash, so when you turned the radio on, it lit the dial head up but was not connected to the radio and the CD player would start. The station selector of course wouldn't work either, just turn. They Walmart etc. have these little CD players that have two tiny speakers, which could also be mounted with something, all hidden.
:::Upside down is fine. Car radio tubes were designed to take a fair bit of abuse.
:::The small cylinder may be a condensor or capacitor to cut radio interference. Newer vehicles had them on the generator and the distributor. There were no mini electronics in 1933, so the power module for the radio I expect is about the size of a pound of butter with a tube and a vibrator in it.
:::6 volts DC is bumped up to over 100 volts AC by the vibrating points. Then the rectifier tube converts that to DC to provide power to the plates of the tubes in the radio proper.
:::The tube filaments in the main radio probably operate on 6 volts from the car battery. The dial lamp has power, so look beyond that for a bad connection.
:::Dave is correct of course. We all want you to have the radio taken out and rebuilt. Even if you got the power supply sorted out, the quality of operation would be disappointing, if it keeps working at all.
::Sandy:
::If you are concerned about the lack of anything good on AM, a lot of the guys that rebuild old AM radios here build a small AM transmitter and play music from whatever source with no connection whatsoever to the antique radio. You could have your car playing music from the thirties and WWII, say Glenn Miller or Duke Ellington coming from a little portable box sitting on the seat next to you, or in the back seat, received just like a radio station. To me, THAT would be cool!
::Lewis
