radiola model 25
10/18/2012 9:54:15 AMjohn meints
what is the best way to gain access to the "workings" inside the catacomb? Looks like best to remove the bottom, but not sure. Melt the wax with heat gun??
10/18/2012 10:28:57 AMBob Masse
:what is the best way to gain access to the "workings" inside the catacomb? Looks like best to remove the bottom, but not sure. Melt the wax with heat gun??
:Hi! John,
We had a presentation, on this topic, at one of our radio club meetings. The guy used his outdoor propane barbecue and adjusted the temperature to around 200F degrees. He then put the catacomb in a large tin foil pan and left it in the barbecue until all the wax/pitch had melted.Looking at it from the slide presentation, he put on, it worked quite well.
Bob Masse
10/18/2012 9:46:36 PMjohn meints
::what is the best way to gain access to the "workings" inside the catacomb? Looks like best to remove the bottom, but not sure. Melt the wax with heat gun??
::Hi! John,
:We had a presentation, on this topic, at one of our radio club meetings. The guy used his outdoor propane barbecue and adjusted the temperature to around 200F degrees. He then put the catacomb in a large tin foil pan and left it in the barbecue until all the wax/pitch had melted.Looking at it from the slide presentation, he put on, it worked quite well.
:Bob Masse
10/18/2012 9:49:07 PMjohn meints
:::what is the best way to gain access to the "workings" inside the catacomb? Looks like best to remove the bottom, but not sure. Melt the wax with heat gun??
:::Hi! John,
::We had a presentation, on this topic, at one of our radio club meetings. The guy used his outdoor propane barbecue and adjusted the temperature to around 200F degrees. He then put the catacomb in a large tin foil pan and left it in the barbecue until all the wax/pitch had melted.Looking at it from the slide presentation, he put on, it worked quite well.
::Bob Masse
:::Thanks for the info!! One more question if I may. Is it best to remove the bottom cover? I have not disturbed the tube socket plate. Thanks John
10/19/2012 10:47:44 AMBob Masse
::::what is the best way to gain access to the "workings" inside the catacomb? Looks like best to remove the bottom, but not sure. Melt the wax with heat gun??
::::Hi! John,
:::We had a presentation, on this topic, at one of our radio club meetings. The guy used his outdoor propane barbecue and adjusted the temperature to around 200F degrees. He then put the catacomb in a large tin foil pan and left it in the barbecue until all the wax/pitch had melted.Looking at it from the slide presentation, he put on, it worked quite well.
:::Bob Masse
::::Thanks for the info!! One more question if I may. Is it best to remove the bottom cover? I have not disturbed the tube socket plate. Thanks John
:Hey John,
http://www.cfp-radio.com/restaurations/radiola26/radiola26-EN-02.html
http://www.pharoahaudio.com/radiola26part4.html
Here are a couple of links to copy and paste. I saw the presentation so long ago that I can't remember everything. If you mean the box pan as the bottom cover, yes from the pictures i see that comes off. To get more info just google "Radiola catacomb". Also you may have to use a higher temp than 200F degrees.
Good luck.
Bob Masse
10/19/2012 9:00:35 PMjohn meints
:::::what is the best way to gain access to the "workings" inside the catacomb? Looks like best to remove the bottom, but not sure. Melt the wax with heat gun??
:::::Hi! John,
::::We had a presentation, on this topic, at one of our radio club meetings. The guy used his outdoor propane barbecue and adjusted the temperature to around 200F degrees. He then put the catacomb in a large tin foil pan and left it in the barbecue until all the wax/pitch had melted.Looking at it from the slide presentation, he put on, it worked quite well.
::::Bob Masse
:::::Thanks for the info!! One more question if I may. Is it best to remove the bottom cover? I have not disturbed the tube socket plate. Thanks John
::Hey John,
:http://www.cfp-radio.com/restaurations/radiola26/radiola26-EN-02.html
:http://www.pharoahaudio.com/radiola26part4.html
:Here are a couple of links to copy and paste. I saw the presentation so long ago that I can't remember everything. If you mean the box pan as the bottom cover, yes from the pictures i see that comes off. To get more info just google "Radiola catacomb". Also you may have to use a higher temp than 200F degrees.
:Good luck.
:Bob Masse
::Thanks for the links. Visual is always better!! John
