Old Westinghouse radio
10/14/2012 2:18:50 PMJohn
I just got this old Westinghouse battery radio. There doesn't appear to be a model number. It says licensed for amateur and experimental use only and made in East Springfield Works with two dates of 10-6-14 5-10-21. It uses one tube which is missing. What would the tube be?? It is a 4 prong tube with three smaller prongs and one large prong.
10/14/2012 3:14:09 PMWarren
WD-11
10/14/2012 3:15:06 PMCarl T
:I just got this old Westinghouse battery radio. There doesn't appear to be a model number. It says licensed for amateur and experimental use only and made in East Springfield Works with two dates of 10-6-14 5-10-21. It uses one tube which is missing. What would the tube be?? It is a 4 prong tube with three smaller prongs and one large prong.
John,
Would it look anything like this?:
http://www.radiomuseum.org/r/rca_aeriola_sr_1.html
Carl T
10/14/2012 4:02:06 PMNorm Leal
Agree, WD11 is the only popular tube with three small and one large pin. Very expensive unless you buy or make a sub.
Should match RCA Radiola Senior schematic.
http://www.nostalgiaair.org/PagesByModel/347/M0040347.pdf
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=WD11
::I just got this old Westinghouse battery radio. There doesn't appear to be a model number. It says licensed for amateur and experimental use only and made in East Springfield Works with two dates of 10-6-14 5-10-21. It uses one tube which is missing. What would the tube be?? It is a 4 prong tube with three smaller prongs and one large prong.
:John,
:Would it look anything like this?:
:http://www.radiomuseum.org/r/rca_aeriola_sr_1.html
:Carl T
10/14/2012 4:06:19 PMWarren
Here is a link to buy a made sub, or make your own.
http://www.dialcover.com/tubes.html
10/14/2012 4:48:45 PMJohn
I was able to match up a picture on the radio attic archives and I have a Aeriola Senior. Don't have the paper that goes in the lid. Any idea how I could get a copy of that lid paper?
:Here is a link to buy a made sub, or make your own.
:http://www.dialcover.com/tubes.html
