10/7/2012 4:35:11 PMchuck(102639:0)
Does anyone know the settings to test the 112A tube on a hickock 800 tube tester?
10/7/2012 5:47:41 PMBob Masse (102641:102639)
:Does anyone know the settings to test the 112A tube on a hickock 800 tube tester?
:Yes,
You use the 12A data which is:
12A 5.0 JR-3200-0 44 68 P4 1650 avg.
Bob masse
10/9/2012 2:30:59 PMchuck(102666:102641)
::Does anyone know the settings to test the 112A tube on a hickock 800 tube tester?
::Yes,
:You use the 12A data which is:
: 12A 5.0 JR-3200-0 44 68 P4 1650 avg.
:Bob masse
::Thanks Bob I will try that.chuck
10/11/2012 3:03:32 PMCHUCK(102694:102666)
:::Does anyone know the settings to test the 112A tube on a hickock 800 tube tester?
:::Yes,
::You use the 12A data which is:
:: 12A 5.0 JR-3200-0 44 68 P4 1650 avg.
::Bob masse
:::Thanks Bob I will try that.chuck
::: I used your settings for the tube.They work fine.There must be something wrong with my tube.It doesn't conduct at 5 volts.I set the filament to 7.5 volts and let it cook trying to regenerate it.It still wouldn't conduct.If I put the filament voltage at 10 volts and hit p4 the tube conducts high current.At that filament setting it turns on the lamp fuse.Must be something wrong in the tube.I tested another 112a and it worked great.any ideas?
