Lou
:A friend has an old phonograph reproducer to sell. Is there an easy way to tell if it works without hooking it to a player?
:Describe the "reproducer".Acoustic or electrical?
:Thanks
:Lou
::A friend has an old phonograph reproducer to sell. Is there an easy way to tell if it works without hooking it to a player?
Here is the method that I use.
I take my finger and rub the end of the needle with it while listening to the output of the reproducer (put in against your ear). You should hear a loud scratching noise, which is the sound of the diaphram responding to your touch.
Lou
:It's an old Silvertone acoustic reproducer that goes on the end of a tone arm.
:Thanks,
:John
::Describe the "reproducer".Acoustic or electrical?
::Thanks
::Lou
:::A friend has an old phonograph reproducer to sell. Is there an easy way to tell if it works without hooking it to a player?
:John:
:Here is the method that I use.
:I take my finger and rub the end of the needle with it while listening to the output of the reproducer (put in against your ear). You should hear a loud scratching noise, which is the sound of the diaphram responding to your touch.
:Lou
::It's an old Silvertone acoustic reproducer that goes on the end of a tone arm.
::Thanks,
::John
:::Describe the "reproducer".Acoustic or electrical?
:::Thanks
:::Lou
::::A friend has an old phonograph reproducer to sell. Is there an easy way to tell if it works without hooking it to a player?
