1000 Volts
10/1/2012 4:01:01 PMBob.
Stewart Warner Vol 6-3 Part# 16 s/b 1000 volts could .01 at 600 volts work O.K?? Whats your opion.
10/1/2012 4:47:54 PMMitch
:Stewart Warner Vol 6-3 Part# 16 s/b 1000 volts could .01 at 600 volts work O.K?? Whats your opion.
Bob,
If it calls for 1000 volts replace it with a 1000 volt rated component. Normally i replace them with 1600 volt components.
Mitch
10/1/2012 5:16:35 PMPeterG. Balazsy
If the original was .01uf @ 1000v
You can use two .02uf @ 630v caps in series which will give you .01 @ 1230v
10/1/2012 5:26:04 PMPaul Knaack
::Stewart Warner Vol 6-3 Part# 16 s/b 1000 volts could .01 at 600 volts work O.K?? Whats your opion.
:Bob,
:If it calls for 1000 volts replace it with a 1000 volt rated component. Normally i replace them with 1600 volt components.
:Mitch
Hello Bob,
If you have two .02 mfd @ 630 volt capacitors you can wire them in series for .01 @ 1260 volt capacitance
Paul
