If the set is just a black and white set, the visible adjustments that you see when it is open; are very tollerent of misadjustment, and you can try slight adjustments without causing trouble to the set, but note where the adjuster aligned before you made any adjustments in the event you get undesired results, you can return it to the original position. Do this as a last step, on older sets the adjsutments were more critical, but the newer sets are more tollerant of errors in production, errors caused by age, etc.
: My white westinghouse tv buzzes at low volume levels or medium level. Brand New out of the box it did this. Had it about a year and never really used it to now when my bedroom tv went and I am using the WW TV often. Doesnt get worse just always buzzes on every channel.
: If the set is just a black and white set, the visible adjustments that you see when it is open; are very tollerent of misadjustment, and you can try slight adjustments without causing trouble to the set, but note where the adjuster aligned before you made any adjustments in the event you get undesired results, you can return it to the original position. Do this as a last step, on older sets the adjsutments were more critical, but the newer sets are more tollerant of errors in production, errors caused by age, etc.
: : My white westinghouse tv buzzes at low volume levels or medium level. Brand New out of the box it did this. Had it about a year and never really used it to now when my bedroom tv went and I am using the WW TV often. Doesnt get worse just always buzzes on every channel.
