: The radio plays with very weak volume. What is the best course of action to take in dignosing & repairng
: this set?
: Hi Charles, There's a lot of possibilities but from experience weak sound is often caused by failed electrolytic coupling capacitors in the audio stages. Try bridging across each one with a small electrolytic, a few microfarad will do to test. If the sound increases that indicates the electrolytic is the culprit. Just use a small capacitor for testing, too large a value may zap a transistor, even 0.1µf plastic cap should do. Don Black.
: : The radio plays with very weak volume. What is the best course of action to take in dignosing & repairng
: : this set?
