Jerry
A used choke can be found at "play things of the past".
http://www.oldradioparts.com/
But he has a $20 min order I think.
Thanks for the reply Peter.
::For the the filter condensers you can use two 8uf caps @450vdc
::You can probably use an 8-10 Henry choke @ 50ma or higher
::A used choke can be found at "play things of the past".
::http://www.oldradioparts.com/
::But he has a $20 min order I think.
