It could have been manufactured by Bandelin Electronic KG, I am not sure.
I need the service manual and the schematick in order to repair the unit. any help will be appreciated.
With Regards,
Shahbaz.
Map Quest really needs to start their directions with # 5 . . . . . . |
:Sir . . . . . Shahbaz
:Can you give me your degree of familiarity with that type of product or our older Amerikanski stalwart, the Watchmaster.
:I am curious if the synchronous motor is running?
:If so, can you adjust it to its different running speed standards ?
:Is the chart paper advancing ?
:Is the "tick " stylus marking ?
:Is the amp chain of the amplified "tick" operating ?
:Is the mike good ? ( or no broken cord from 123,475 flexures or bad connector )
:The last two aspects can be tested by plugging in and the use of the earphone for monitoring of the "ticks"
:One might be able to work on the evaluatoin of the unit without a schema, with adequate close observations and tests.
:Map Quest really needs to start their directions with # 5 . . . . . .
:as I'm pretty darn sure that I know how to initially get OUT of my neighborhood.
