That's an unusual transformer with a single tapped secondary. You will need to make changes but available power transformers are here:
Be sure a replacement transformer fits on the chassis.
:My friend has an RCA-100 radio (the schematic is here on a thread I started about a few days ago)...The power tranny is bad, starts getting hot, even without the rectifier plugged in. There is also that black 'tar' stuff underneath that oozed out. So I'm assuming its bad.
:I am trying to help him find a tranny (used, not new due to cost). Does anyone have something that would work, in their boneyard, for this set?
:http://www.nostalgiaair.org/PagesByModel/764/M0015764.pdf
It is kinda an odd duck. It looks like the tube filaments are in series and have to be supplied with around 25 volts from the secondary.
Clifton
:Brian
: That's an unusual transformer with a single tapped secondary. You will need to make changes but available power transformers are here:
:http://www.oldradioparts.com/2a23efl.txt
: Be sure a replacement transformer fits on the chassis.
::My friend has an RCA-100 radio (the schematic is here on a thread I started about a few days ago)...The power tranny is bad, starts getting hot, even without the rectifier plugged in. There is also that black 'tar' stuff underneath that oozed out. So I'm assuming its bad.
::I am trying to help him find a tranny (used, not new due to cost). Does anyone have something that would work, in their boneyard, for this set?
::http://www.nostalgiaair.org/PagesByModel/764/M0015764.pdf
I agree, very difficult to find the exact transformer.
:Norm,
:It is kinda an odd duck. It looks like the tube filaments are in series and have to be supplied with around 25 volts from the secondary.
:Clifton
::Brian
:: That's an unusual transformer with a single tapped secondary. You will need to make changes but available power transformers are here:
::http://www.oldradioparts.com/2a23efl.txt
:: Be sure a replacement transformer fits on the chassis.
:::My friend has an RCA-100 radio (the schematic is here on a thread I started about a few days ago)...The power tranny is bad, starts getting hot, even without the rectifier plugged in. There is also that black 'tar' stuff underneath that oozed out. So I'm assuming its bad.
:::I am trying to help him find a tranny (used, not new due to cost). Does anyone have something that would work, in their boneyard, for this set?
:::http://www.nostalgiaair.org/PagesByModel/764/M0015764.pdf
Generally black is AC input, red - high voltage with a centertap, green - 6.3 volts, yellow - 5 volts.
Since you may not be able to tell with faded colors next best is using an ohm meter. AC input, which you found, will most likely read in 10 - 30 ohm range. Filaments both 6.3 and 5 volts almost zero ohms. Red - high voltage - a couple hundred ohms with center tap about half way between the two.
Any extra wires may be filament center taps?
:I just found a transformer in my junkpile that is almost physically the same size (the lamination section is slightly 'thinner' than the RCA100), and it would mount easy....Trouble is, I need some help to figure out what the leads are (I know there is a code for tranny wires, but these are faded and don't seem to match the standard code). Looks like I found the primary side (still had a piece of the power cord attached)...There are 8 other leads coming out, of which 6 were taped over (as if they weren't used), the other 2 wires go to some sort of a 2 round prong plug as if it went into a female socket on a chassis.
:Any ideas here to de-code this? It has the code 'E-1041' stamped on it, and the number '17' also.
That's a good idea. It will also show if the transformer is shorted. Prevent blowing a breaker...
:Thanks for the info Norm...Is there any advantage of hooking the tranny's 120vac primary leads up to a Variac, and then measuring the voltages on the unknown wires, or isn't that practical?
The restriction then, as Norm mentioned, will be size.
I am too far away in Canada to send you a used transformer. You would have to pay the bomb squad at customs on top of the shipping. Good luck.
:Norm,
:Clifton
::Brian
I wonder if sometimes the design of the radio was matched to parts that were readily available at the time? Maybe that was a cheap transformer so they drew up a circuit that could utilize it? Just speculating.
