::If this is an incorrect post folks then please disregard. I am working on what must be a home brew radio. No information whatsoever but a very nice radio non the less.Chassis appx 1932 ish. The radio has mounted within the cabinet a Hammond calendar electric clock, The clock does not work.
::The internal 'coil' is open circuit. Looks just like a choke?? The clock has no synchronous motor - just this 'co;i' with no apparent connection to the mechanism. If I did not know better first guess would be that the clock is a slave but this cant be surely since a label on tha back states ' twist to start. 50c 115 volt. It's a mystery.
::Frank. Doncaster England.
:Frank: I have an early 30's Hammond electric clock with calendar, so I think it may be similar to mine. The field coil should be next to a sealed motor with a single gear coming out of the side. The coil causes a magnetic field to spin a gear inside. Is there a round, open area near your coil? Perhaps someone took it out when it failed to work. These motors can usually be revived by drilling a small hole and putting about a teaspoon of oil inside, then sealing the hole. I use epoxy glue, but some folks solder it up. The field coil in mine also was open and had to be replaced. I was lucky to find an old clock repair shop that had a coil that worked. You might be able to find someone who could rewind it, but I imagine it would be expensive. At any rate, the Hammond is my favorite clock in my collection and was worth it to me to repair it. Mark from Kalamazoo
Mark
Many thanks for the info. This is the strangest motor i have ever seen. A remote field coil! Whatever next? I should be able to make something of the clock now - hopefully. The radio section has all the hallmarks of a Philco Chassis Somehting like a Model 80. It is all contained in a scrolled birchwood cabinet with fretwored birds and leaves.I picked up the radio in MA during a trip in May
Thanks again
Frank Doncaster England.
