In remembering that unit . . . . . and thats some HARD remembering, I 'm thinking of a common steel platter and being joined to its pot metal central shaft at its very center portion. Then drop the platter down into place again and try it to see if you corrected enough or have overdone it and react accordingly. Thasssitt . . . . . 73's de Edd The 5 P's of Painting : Preparation Prevents Piss Poor Performance |
:Dave: Could it end up cracking if you try to flatten it out? That might be worse. Any way you could make something to go on top that would bring the low side up to the level of the high side? Then you could play records with that and remove it when it is just for show. Just a thought. mark from kalamazoo
