There were mica caps made like that for transmitters. If it doesn't have leakage, use it.
:I have a what I think is a big mica cap. It has a screw hole on each side for mounting . Could it be used in a circuit where a .05 ceramic disc was intended. It is a michigan mighty qrp transmitter that I'm working on. I'm making it with full size components on a oak breadboard.
Best way is with a cap tester which has high voltage available. There are other ways.
Could put the cap in series with a DC power supply and current meter. Turn on the supply. At first a meter will read current then settle to Zero. If it doesn't go to zero cap is leaky.
::Andy
:: There were mica caps made like that for transmitters. If it doesn't have leakage, use it.
:::I have a what I think is a big mica cap. It has a screw hole on each side for mounting . Could it be used in a circuit where a .05 ceramic disc was intended. It is a michigan mighty qrp transmitter that I'm working on. I'm making it with full size components on a oak breadboard.
:How do I test it?
w. . . . .a. . . . .i. . . . .t. . . . . i . . . . . n. . . . . g for an initial charging surge voltage of the capacitor to gradually /and/ eventually dissipate on down to the REAL leakage value . . . IF there is any leakage even being existent. How Do They Get Deer To Cross The Road Only At Those Yellow Road Signs ? |
:Andy
: Best way is with a cap tester which has high voltage available. There are other ways.
: Could put the cap in series with a DC power supply and current meter. Turn on the supply. At first a meter will read current then settle to Zero. If it doesn't go to zero cap is leaky.
:::Andy
::: There were mica caps made like that for transmitters. If it doesn't have leakage, use it.
::::I have a what I think is a big mica cap. It has a screw hole on each side for mounting . Could it be used in a circuit where a .05 ceramic disc was intended. It is a michigan mighty qrp transmitter that I'm working on. I'm making it with full size components on a oak breadboard.
::How do I test it?
: : : : ![]() : : : : : : : :Sir Andy . . . . . : : :After initially “really searching” your specified “michigan mighty qrp transmitter “ it is revealing to be but a mere 12 Volt powered transistor “peanut whistle” and not encroaching upon the tube powered behemoths incorporating kilovolts of plate supply voltage . : : :Usually those styles of ear mounted postage stamp micas were rated upwards of 500 VDC and on upwards for transmitter use. : : :In your situation, merely ohm it out on your highest available ohms scale. : : :OR if you want a more subjective dynamic testing, use your 12 DC supply or (2) 9 V rectangular “transistor radio batteries” plugged together in series : : :One end of a clip lead goes to the free POSITIVE term end of the “battery” with the other end of that clip lead going to one ear of the mica capacitor. : : :One lead of ANOTHER clip lead goes to the NEGATIVE term end of the “battery” with the other end of that clip lead going to the NEGATIVE metering lead. : : :The POSITIVE metering lead is then touched to the free ear of the mica capacitor. : : :Then you switch the metering range on downscale to its lowest range, any reading that eventually doesn’t drop on down and stays at a level is indicative of DC leakage . . . . and reason for rejection. : : :To even FURTHER evaluate that cap capability at higher voltages, think of any piece of tube equipment that you have, such that you would have hundreds of DC volts available from a similar clipping in and borrowing from its power supply output. : : :This time you insert a 1 meg current limiting resistor in series with the test lead that taps off the B+ from the “donor” supply, then proceed with the prior test in the same manner. : : :( This time you keep one hand in your pocket . . . if being in a touchy metering situation) : : :This modified procedure then lets you find the exact capability of that capacitor, yet, in a non destructive test mode. : : :Notice: : : :I n the higher voltage testing and with the intermediate capacitance value you specify, you may be : : w. . . . .a. . . . .i. . . . .t. . . . . i . . . . . n. . . . . g for an initial charging surge voltage of the capacitor to gradually /and/ eventually dissipate on down to the REAL leakage value . . . IF there is any leakage even being existent. : : :A speedy work around solution is to just manipulate your wired “contraption” around, until you can short the + & - meter leads to each other. That immediately fully charges the capacitor and if the leads are then un-shorted, any voltage showing up from the just prior ZERO volts is being DC leakage. : : : : : :73's de Edd : : : : : : : How Do They Get Deer To Cross The Road Only At Those Yellow Road Signs ? : : : : : ![]() : : : |
