Rubber Grommets
7/22/2012 6:12:28 PMBob
Other then RD & AE who sells ruber grommets that come close to fit 1930's radios?
7/22/2012 6:21:49 PMNorm Leal
Bob
Try Radio Shack or Hardware Stores. Depending on the use a piece of rubber hose for cars may work.
:Other then RD & AE who sells ruber grommets that come close to fit 1930's radios?
7/22/2012 7:04:10 PMLou
I have found a LOT of good grommets for use under chassis at ACE hardware ( assuming you have one ). The hardware dept is extensive and I have made nice grommet inserts and other difficult rubber parts for radios from the stuff they sell.
Lou
:Bob
: Try Radio Shack or Hardware Stores. Depending on the use a piece of rubber hose for cars may work.
::Other then RD & AE who sells ruber grommets that come close to fit 1930's radios?
7/22/2012 7:26:25 PMDale
:I have found a LOT of good grommets for use under chassis at ACE hardware ( assuming you have one ). The hardware dept is extensive and I have made nice grommet inserts and other difficult rubber parts for radios from the stuff they sell.
:Lou
::Bob
:: Try Radio Shack or Hardware Stores. Depending on the use a piece of rubber hose for cars may work.
:::Other then RD & AE who sells ruber grommets that come close to fit 1930's radios?
Hi Gents, here is a good place, has quite a selection and they are good, have used them myself.http://www.renovatedradios.com/parts.html
7/24/2012 8:56:19 PMBrett
I get a lot of mine from McMaster Carr. I order from the catalog at work.
