27Tube substitution
7/12/2012 10:51:13 PMJoe
Hello, is there another tube I can replace the 27 with in my Atwater kent here in Australia.
Thanking you
7/12/2012 11:14:29 PMJohn
:Hello, is there another tube I can replace the 27 with in my Atwater kent here in Australia.
:Thanking you
The only good substitution listed is the 56.
The 56 draws less heater current which is a good thing but has a maximum plate voltage rating of 250V versus 275 for the 27. It is highly unlikely that the Atwater is using that high of plate voltage anyway. They both are 2.5V. filament (heater) tubes which is why there is only one direct sub. John
7/12/2012 11:57:51 PMJoe
::Hello, is there another tube I can replace the 27 with in my Atwater kent here in Australia.
::Thanking you
:The only good substitution listed is the 56.
:The 56 draws less heater current which is a good thing but has a maximum plate voltage rating of 250V versus 275 for the 27. It is highly unlikely that the Atwater is using that high of plate voltage anyway. They both are 2.5V. filament (heater) tubes which is why there is only one direct sub. John
7/13/2012 12:00:29 AMJoe
Thank you for the information John
Regards
Joe
