If your out- putsie transformateur , that is mounted on the SPEAKER is " 'moking " and getting all hot, the best thing that we could hope for is a short , low resistance or arcing to be occuring on one (or both) of the the set of those two capacitors on the plate circuitry of the output tubes to ground. Or upwards of a 1000 V rating if being replaced. Now . . . . .CHECK it out !
:Hi, I am a first timer on here and a first timer with old radio repair. I bought my first old radio 1946 crosley 106CP. It was in great shape guy said it just needed a new power cord. I have been reading up and decided to change all the caps also. Once inside I found the tuner string was gone and replaced that too. I just tried it out today for the first time. It actually powered up and got ome decent channels. I let it run for about an hour no problems. When I tried it again later I heard some crackling and smelled smoke. It tuned out to be the tranformer on the speaker. It was heatng up an I saw some bubbling so I shut it down. Why is it happening the second time around? Also the tuner only travels about 1/3 of the dial what would stop it? Thanks.
:Sir Randall . . . . .
:MAN . . . . . I was 'soitanly hoping that I could provide you a clearer schematic of this set, but, alas, 'twas not to be.
:Soooooo . . . . . lets just trod thru wit what we gots !
:WOW . . . . Powell Crosley had great aspirations with this unit . . . . one expects push pull audio output tube usage design on the better sets.
:This one went one up and had PARALLEL push pull tubes.
: If your out- putsie transformateur , that is mounted on the SPEAKER is " 'moking " and getting all hot, the best thing that we could hope for is a short , low resistance or arcing to be occuring on one (or both) of the the set of those two capacitors on the plate circuitry of the output tubes to ground.
:That would make the primary of the output transformer to be VERY mad.
:Since it normally has only dissipate the higher load presented by the output tubes conduction on power audio.
:Those parts markings SEEMS to be items 39 and 40 with value of .0033 mfd and at a 600VDC rating.
:Or upwards of a 1000 V rating if being replaced.
:Lift the ground connection of both and ohm them out.
:It is even permissible to run the set without them for testing, to see if that is only occurring at a dynamic operational condition ( such as arcing over )
:I certainly hope that will be your problem source, and has not damaaged your output transformer yet.
: Now . . . . .CHECK it out !
: Always listen to experts. They'll tell what can't be done and why. Then do it.
::Hi, I am a first timer on here and a first timer with old radio repair. I bought my first old radio 1946 crosley 106CP. It was in great shape guy said it just needed a new power cord. I have been reading up and decided to change all the caps also. Once inside I found the tuner string was gone and replaced that too. I just tried it out today for the first time. It actually powered up and got ome decent channels. I let it run for about an hour no problems. When I tried it again later I heard some crackling and smelled smoke. It tuned out to be the tranformer on the speaker. It was heatng up an I saw some bubbling so I shut it down. Why is it happening the second time around? Also the tuner only travels about 1/3 of the dial what would stop it? Thanks.
Thanks for the tips. As I said I am a first timer and have little to no experience even with schematics but I think I found what you said on the schematic. I will check those out. I did replace them originally however. As for the tuning condenser, when I got it the chord was already missing so I don't know how it was strung. But even with no chord on it the drum doesn't turn any farther.
You would be in trouble if that vane has been bent inwardly. Le tuning condensateur: |
:Hi Ed
:Thanks for the tips. As I said I am a first timer and have little to no experience even with schematics but I think I found what you said on the schematic. I will check those out. I did replace them originally however. As for the tuning condenser, when I got it the chord was already missing so I don't know how it was strung. But even with no chord on it the drum doesn't turn any farther.
On problem #2 with the tuning condenser. You were right with the first guess. I think my tuning chord was not right. Kept the condenser from full travel. I don't suppose there is a diagram anywhere of how to wrap it?
randall
. . . . .but, if you didn't get the tingly part . . . probe your fingertips up around and into the AC wiring area . |
::Hi Edd, well I fooled with it and looked at the area around the speaker jack. I saw what may have been a short and fixed it. Then I messed with the tuner chord. I managed to figure that out also. So everything looks good. Powered it up and no smoking so far. Tuner went all the way around too. Gonna put it back together and se what it does. Thanks for your help! I may try another!
