I normally purchase the kits from Just Radios in Canada but they are adding 50 volt capacitors to the kits. I have plenty of the 50 volt capacitors and rarely need them for the old radios.
Is there another supplier out there that sells the kits without the 50 volt capacitors?
Mitch
I have tried http://www.wjoe.com/capacitors.htm
Good pricing and products.
Mitch
http://www.radioantiques.com/
Clifton
:::Hello everyone,
:::I normally purchase the kits from Just Radios in Canada but they are adding 50 volt capacitors to the kits. I have plenty of the 50 volt capacitors and rarely need them for the old radios.
:::Is there another supplier out there that sells the kits without the 50 volt capacitors?
:::Mitch
:::Hi! Mitch,
::I don't like the kits because after the most common ones are gone a guy has to start putting 2 or 3 together to make one. Going by what's left in your kit you can figure out which ones you use the most of.
::Take a look here to see if this will work for you.
::http://www.wjoe.com/capacitors.htm
::I've used them twice before with good results.
::Bob Masse
:Thank you for the posts,
:I have tried http://www.wjoe.com/capacitors.htm
:Good pricing and products.
:Mitch
