zenith model b835
6/13/2012 10:30:15 AMNick Magnano
First I want to say thank you Dennis and Paul for all of their help finding me the re-string diagram, it worked great.
My next dilemma is that the AM plays great but I can’t receive any FM channels, any thoughts on why? Anyone
6/13/2012 11:08:19 AMBill G.
Hi Nick,
I commonly restore Zenith H723, a little brother to yours. It is older and has no AFC.
This is a common problem. It usually is caused by silver mica disease in the discriminator IF.
This can be tested by reading the voltages on the 19T8 diodes, (pins 1, 2 and 3). If the discriminator is bad these voltages will be positive.
The problem is so common, I once replaced the discriminator without testing the voltages only to find the 19T8 was bad. I felt a little cheap. Be sure to test the tubes, 12AU6 and 19T8. They are rarely the cause, but it can happen.
Best Regards,
Bill Grimm
6/13/2012 4:41:12 PMNick
:Hi Nick,
: I commonly restore Zenith H723, a little brother to yours. It is older and has no AFC.
: This is a common problem. It usually is caused by silver mica disease in the discriminator IF.
: This can be tested by reading the voltages on the 19T8 diodes, (pins 1, 2 and 3). If the discriminator is bad these voltages will be positive.
: The problem is so common, I once replaced the discriminator without testing the voltages only to find the 19T8 was bad. I felt a little cheap. Be sure to test the tubes, 12AU6 and 19T8. They are rarely the cause, but it can happen.
:Best Regards,
:Bill Grimm
6/13/2012 4:42:05 PMNick
Thank you so much for the info I'll check those out
::Hi Nick,
:: I commonly restore Zenith H723, a little brother to yours. It is older and has no AFC.
:: This is a common problem. It usually is caused by silver mica disease in the discriminator IF.
:: This can be tested by reading the voltages on the 19T8 diodes, (pins 1, 2 and 3). If the discriminator is bad these voltages will be positive.
:: The problem is so common, I once replaced the discriminator without testing the voltages only to find the 19T8 was bad. I felt a little cheap. Be sure to test the tubes, 12AU6 and 19T8. They are rarely the cause, but it can happen.
::Best Regards,
::Bill Grimm
