Car radios
6/7/2012 2:23:34 PMRalph Schneider
I work on alot of old car radios, why did GM stick with the vibrator and high voltage power supply after Ford and Chrysler switched to transitor out puts in 1957? I recently fixed a 1957 Chevy radio and was suprized to see it had a transistor out put, but a 1957 Oldsmobile still has a vibrator and the oz4!
6/7/2012 4:12:54 PMWarren
Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
6/8/2012 12:38:09 AMMAG
:Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
6/8/2012 5:11:09 AMLewis L.
::Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
:You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
:Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
My 57 Chevy had a 12 Volt plate/transistor hybrid, but you could also get an all transistor radio that would fit in the same space, also Delco.
6/8/2012 8:53:03 PMJohn Kogel
:::Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
::You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
::Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
:My 57 Chevy had a 12 Volt plate/transistor hybrid, but you could also get an all transistor radio that would fit in the same space, also Delco.
:Lewis
My 49 Chev business coupe had the radio mounted vertical, pushbuttons curving down to two knobs. All I know is that it could kill a 6 volt battery in about 20 minutes.
6/8/2012 9:11:31 PMNorm Leal
John
Those 49 Chev radios were fused at 14 amps and almost drew that much...
::::Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
:::You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
:::Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
::My 57 Chevy had a 12 Volt plate/transistor hybrid, but you could also get an all transistor radio that would fit in the same space, also Delco.
::Lewis
:My 49 Chev business coupe had the radio mounted vertical, pushbuttons curving down to two knobs. All I know is that it could kill a 6 volt battery in about 20 minutes.
6/9/2012 8:27:18 PMRalph Schneider
:John The fact that they made 5 different radios for 1957, clears it all up. I have a friend that owns 2 1962 chevys, on has a all transistor delco radio and the other has a tube hybrid, both are factory radios.
:Those 49 Chev radios were fused at 14 amps and almost drew that much...
:::::Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
::::You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
::::Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
:::My 57 Chevy had a 12 Volt plate/transistor hybrid, but you could also get an all transistor radio that would fit in the same space, also Delco.
:::Lewis
::My 49 Chev business coupe had the radio mounted vertical, pushbuttons curving down to two knobs. All I know is that it could kill a 6 volt battery in about 20 minutes.
6/10/2012 10:10:15 PMJohn
I was looking for info on a Motorola radio repair and stumbled upon this, nice pics of a '49 Chev radio. That was a unique plastic they used on the knobs, Plaskon?
This seller says he has 3000 car radios.
http://www.ebay.com/itm/49-50-Chev-Chevy-car-radio-Repaired-Good-Working-Nice-original-stock-6-volt-1950-/320911858441?hash=item4ab7d65b09&item=320911858441&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
::John The fact that they made 5 different radios for 1957, clears it all up. I have a friend that owns 2 1962 chevys, on has a all transistor delco radio and the other has a tube hybrid, both are factory radios.
::Those 49 Chev radios were fused at 14 amps and almost drew that much...
::::::Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
:::::You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
:::::Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
::::My 57 Chevy had a 12 Volt plate/transistor hybrid, but you could also get an all transistor radio that would fit in the same space, also Delco.
::::Lewis
:::My 49 Chev business coupe had the radio mounted vertical, pushbuttons curving down to two knobs. All I know is that it could kill a 6 volt battery in about 20 minutes.
6/14/2012 6:52:12 PMharold
:I was looking for info on a Motorola radio repair and stumbled upon this, nice pics of a '49 Chev radio. That was a unique plastic they used on the knobs, Plaskon?
:This seller says he has 3000 car radios.
:http://www.ebay.com/itm/49-50-Chev-Chevy-car-radio-Repaired-Good-Working-Nice-original-stock-6-volt-1950-/320911858441?hash=item4ab7d65b09&item=320911858441&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
:::John The fact that they made 5 different radios for 1957, clears it all up. I have a friend that owns 2 1962 chevys, on has a all transistor delco radio and the other has a tube hybrid, both are factory radios.
:::Those 49 Chev radios were fused at 14 amps and almost drew that much...
:::::::Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
::::::You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
::::::Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
:::::My 57 Chevy had a 12 Volt plate/transistor hybrid, but you could also get an all transistor radio that would fit in the same space, also Delco.
:::::Lewis
::::My 49 Chev business coupe had the radio mounted vertical, pushbuttons curving down to two knobs. All I know is that it could kill a 6 volt battery in about 20 minutes.
I want to ask the car radio folks that are on this post--did you ever note the long shafts (and heavy cast metal knobs) on car radios causing vol. and tone control premature problems, or did I just dream it.
Harold
6/14/2012 11:17:07 PMNorm Leal
Harold
Haven't noticed long shaft and heavy metal knobs causing problems but the switches often go bad. They have to handle high current of the car radios.
::I was looking for info on a Motorola radio repair and stumbled upon this, nice pics of a '49 Chev radio. That was a unique plastic they used on the knobs, Plaskon?
::This seller says he has 3000 car radios.
::http://www.ebay.com/itm/49-50-Chev-Chevy-car-radio-Repaired-Good-Working-Nice-original-stock-6-volt-1950-/320911858441?hash=item4ab7d65b09&item=320911858441&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
::::John The fact that they made 5 different radios for 1957, clears it all up. I have a friend that owns 2 1962 chevys, on has a all transistor delco radio and the other has a tube hybrid, both are factory radios.
::::Those 49 Chev radios were fused at 14 amps and almost drew that much...
::::Norm
::::::::Are you sure that was a 1957 Chevy radio? I have owned 57 Chevys. The Nomad had the top of the line AM radio. 0Z4, vibrator, two 12V6.
:::::::You are both right about 57 Chevrolets, there were 5 different radios for 57 if you count the 57 Corvette, a carry-over from 56. The passenger car line had a manual tune with vibrator and single 12V6, a push-button 5 tube, 1 transistor, a Wonder-Bar with vibrator and 2-12V6 tubes, and a push-button radio with vibrator and 2-12V6 tubes.
:::::::Actually, GM had a radio with transistor output in 1956, a year before Ford. The 56 Corvette radio had push-pull 2N173 output transistors. An oddity, the 57 Cadillac Brougham had 13 transistors, no tubes.
::::::My 57 Chevy had a 12 Volt plate/transistor hybrid, but you could also get an all transistor radio that would fit in the same space, also Delco.
::::::Lewis
:::::My 49 Chev business coupe had the radio mounted vertical, pushbuttons curving down to two knobs. All I know is that it could kill a 6 volt battery in about 20 minutes.
:I want to ask the car radio folks that are on this post--did you ever note the long shafts (and heavy cast metal knobs) on car radios causing vol. and tone control premature problems, or did I just dream it.
:Harold
6/17/2012 8:10:02 AMDanny
I have a 1959 chevrolet car radio and it actually use 4 tube and one output transistor
Danny
