Unusual combination of octal and older tubes. L42B ballast was mainly used in Emerison DP332 but that's not this radio.
Enter what's known here:
http://www.grillecloth.com/sylvania/tubelist.php?comp=&mod=&Num=7&tube1=25a6&tube2=25z5&tube3=76&tube4=&ball=lb42&Submit=Submit&db=5
:I got this radio along with a nice Philco console. At first I had no idea what it was, but I figured out that it is a chair side radio and table.
:The problem is that I have NO idea of it's make or model. The label has a lot of licensing and patent numbers. It also says Hazeltine Corporation. The tube lineup includes-25Z5, 25A6, 76, 6K5, 6D6 and 6A7. It also has an L42B ballast. I could really use a schematic.
My theory is that it might be a radio built as part of a radio course. I saw a radio very similar on ARF. It is a Knight, (Allied Radio) B10704. But this is not the same.
It's hard to see, but on the chassis there is a plate covering a hole that might have been for a transformer. that implies to me that the chassis is generic.
Is it possible it may be a Pacific Radio Corp Model 36? That radio has a close tube lineup. It is listed in Rider's Volume 10 (1939).
Clifton
::Hi Terry
:: Unusual combination of octal and older tubes. L42B ballast was mainly used in Emerison DP332 but that's not this radio.
:: Enter what's known here:
::http://www.grillecloth.com/sylvania/tubelist.php?comp=&mod=&Num=7&tube1=25a6&tube2=25z5&tube3=76&tube4=&ball=lb42&Submit=Submit&db=5
:::I got this radio along with a nice Philco console. At first I had no idea what it was, but I figured out that it is a chair side radio and table.
:::The problem is that I have NO idea of it's make or model. The label has a lot of licensing and patent numbers. It also says Hazeltine Corporation. The tube lineup includes-25Z5, 25A6, 76, 6K5, 6D6 and 6A7. It also has an L42B ballast. I could really use a schematic.
:Not enough info.
:My theory is that it might be a radio built as part of a radio course. I saw a radio very similar on ARF. It is a Knight, (Allied Radio) B10704. But this is not the same.
:It's hard to see, but on the chassis there is a plate covering a hole that might have been for a transformer. that implies to me that the chassis is generic.
Okay, we're definitely getting closer.
The top photo is the tube layout for the 36.
The bottom is the mystery radio
:::Hi Terry
::: Unusual combination of octal and older tubes. L42B ballast was mainly used in Emerison DP332 but that's not this radio.
::: Enter what's known here:
:::http://www.grillecloth.com/sylvania/tubelist.php?comp=&mod=&Num=7&tube1=25a6&tube2=25z5&tube3=76&tube4=&ball=lb42&Submit=Submit&db=5
::::I got this radio along with a nice Philco console. At first I had no idea what it was, but I figured out that it is a chair side radio and table.
::::The problem is that I have NO idea of it's make or model. The label has a lot of licensing and patent numbers. It also says Hazeltine Corporation. The tube lineup includes-25Z5, 25A6, 76, 6K5, 6D6 and 6A7. It also has an L42B ballast. I could really use a schematic.
::Not enough info.
::My theory is that it might be a radio built as part of a radio course. I saw a radio very similar on ARF. It is a Knight, (Allied Radio) B10704. But this is not the same.
::It's hard to see, but on the chassis there is a plate covering a hole that might have been for a transformer. that implies to me that the chassis is generic.
"Licensed only for amateur, experimental and broadcast reception. The manufacture and/or sale of this apparatus does not imply any license under any patent relating to the structure or manufacture of this radio. (followed by 20 patent numbers)
Superheterodyne-the following (11)
Automatic Volume control the following-(9)
Dynamic speaker (9)
Also one or more of the following- (104)
Licensed by Hazeltine Corporation only for educational purposes and private non-commercial use under one or more of the following patents or pending applications (over 100)
25-221186"
(Ow- my eyes hurt)
With the same tube lineup, the schematic for the PRC radio should be close enough for repairs. Wouldn't think the tube layout would matter so much.
Clifton
::Hi Terry,
::Is it possible it may be a Pacific Radio Corp Model 36? That radio has a close tube lineup. It is listed in Rider's Volume 10 (1939).
::Clifton
:Okay, we're definitely getting closer.
:The top photo is the tube layout for the 36.
:The bottom is the mystery radio
::::Hi Terry
:::: Unusual combination of octal and older tubes. L42B ballast was mainly used in Emerison DP332 but that's not this radio.
:::: Enter what's known here:
::::http://www.grillecloth.com/sylvania/tubelist.php?comp=&mod=&Num=7&tube1=25a6&tube2=25z5&tube3=76&tube4=&ball=lb42&Submit=Submit&db=5
::::Norm
:::::I got this radio along with a nice Philco console. At first I had no idea what it was, but I figured out that it is a chair side radio and table.
:::::The problem is that I have NO idea of it's make or model. The label has a lot of licensing and patent numbers. It also says Hazeltine Corporation. The tube lineup includes-25Z5, 25A6, 76, 6K5, 6D6 and 6A7. It also has an L42B ballast. I could really use a schematic.
:::Not enough info.
:::My theory is that it might be a radio built as part of a radio course. I saw a radio very similar on ARF. It is a Knight, (Allied Radio) B10704. But this is not the same.
:::It's hard to see, but on the chassis there is a plate covering a hole that might have been for a transformer. that implies to me that the chassis is generic.
Yep and I REALLY appreciate the help. I'm re-capping the set now. A good challenge is always fun, unless you screw up of course. :)
:::Hi Terry,
:::Is it possible it may be a Pacific Radio Corp Model 36? That radio has a close tube lineup. It is listed in Rider's Volume 10 (1939).
:::Clifton
::Okay, we're definitely getting closer.
::The top photo is the tube layout for the 36.
::The bottom is the mystery radio
:::::Hi Terry
::::: Unusual combination of octal and older tubes. L42B ballast was mainly used in Emerison DP332 but that's not this radio.
::::: Enter what's known here:
:::::http://www.grillecloth.com/sylvania/tubelist.php?comp=&mod=&Num=7&tube1=25a6&tube2=25z5&tube3=76&tube4=&ball=lb42&Submit=Submit&db=5
:::::Norm
::::::I got this radio along with a nice Philco console. At first I had no idea what it was, but I figured out that it is a chair side radio and table.
::::::The problem is that I have NO idea of it's make or model. The label has a lot of licensing and patent numbers. It also says Hazeltine Corporation. The tube lineup includes-25Z5, 25A6, 76, 6K5, 6D6 and 6A7. It also has an L42B ballast. I could really use a schematic.
::::Not enough info.
::::My theory is that it might be a radio built as part of a radio course. I saw a radio very similar on ARF. It is a Knight, (Allied Radio) B10704. But this is not the same.
::::It's hard to see, but on the chassis there is a plate covering a hole that might have been for a transformer. that implies to me that the chassis is generic.
You're right. No problem.
I haven't cranked it up yet because I'm moving and all of my bench stuff is packed.
It's always the very thing you need that is packed away in an unmarked box.
:::Hi Terry,
:::Clifton
:::::Hi Terry
:::::Norm
The tube lineup of Pacific 603 is: 6A7, 6D6, 75, 6K5, 25A6, 25Z5, 6U5.
This schematic is NOT on NostalgiaAir though.
