Good luck and good listening
Hi Mingram,
I suggest that you measure all the coils in the aerial circuit to see if any are open circuit. Also the small capacitors could be leaky or have silver migration across the mica insulation. This can cause crackling and noise. If you find an open winding, they often corrode where the wire joins the terminal and can be repaired with care. You might have to extend the end of the wire with another piece of fine wire or you might be able to unwind one turn to get extra length. Good luck, Don.
