I like to use a slo blo fuse. If you know the rated power that the receiver takes ( sometimes listed as the number of watts on the back of the receiver), you can figure the amps. P = IE, P (watts) = I (amps) X V ( volts). The I would rate the fuse at appx 2x higher that, for example for a 2 amp radio draw use a 4 amp fuse.
Lou
:Hello all.What is the best kind (fast/slow blow) and amp rating fuse to use for the B+ just in case of short etc.. (to protect rectifier /transformer etc..)....for 7- 9 tube Push/pull radio ..or how do you figure this out.Do you add the maximum current output of all the tubes ,including eye tube(6U5 etc.), (except the rectifier) for maximum current ???
