Best image I've seen so far is at this link:
http://antiqueradios.com/gallery/v/Stewart-Warner/1940_Stewart_Warner_Air_Pal.jpg.html
It's missing the 25D8, not an expensive tube but not easily available either.
There's no model number anywhere on the bakelite case or inside on the chassis, and there are a LOT of Stewart Warner sets listed here! The chassis does have some partially obscured indications on it:
xxx7-32
CHASSIS
xxx is unreadable, and I'm fairly sure about the "7". The "-32" is clear.
Radio has a 12SA7, 70L7, and the 25D8. Anybody have the schematic, or model number so I can find it on the site?
Mark
PAL350 (at) yahoo (dot) com
With those unusual tubes it's fairly easy.
http://www.grillecloth.com/sylvania/tubelist.php?comp=stewar&mod=&Num=3&tube1=25d8&tube2=70l7&tube3=12sa7&tube4=&ball=&Submit=Submit&db=5
http://www.nostalgiaair.org/PagesByModel/110/M0021110.pdf
:I recently got "gifted" with this radio, which may be more of a curse than a gift. :)
:Best image I've seen so far is at this link:
:http://antiqueradios.com/gallery/v/Stewart-Warner/1940_Stewart_Warner_Air_Pal.jpg.html
:It's missing the 25D8, not an expensive tube but not easily available either.
:There's no model number anywhere on the bakelite case or inside on the chassis, and there are a LOT of Stewart Warner sets listed here! The chassis does have some partially obscured indications on it:
:xxx7-32
:CHASSIS
:xxx is unreadable, and I'm fairly sure about the "7". The "-32" is clear.
:Radio has a 12SA7, 70L7, and the 25D8. Anybody have the schematic, or model number so I can find it on the site?
:Thanks,
:Mark
:PAL350 (at) yahoo (dot) com
