Freed Eiseman NR6 slight audio distortion
5/19/2012 9:03:32 AMDon Christensen
Hello from a newbie in Idaho. The subject line says it all. I can't quite get a station tuned in without a bit of distortion. At low audio through headphones it sounds better. Any ideas would be appreciated.
tnx.
don
5/19/2012 10:23:19 AMNorm Leal
Hi Don
Detector grid resistor may be open? The radio will still operate but distort with this resistor open. Two meg was a fairly common value.
http://www.nostalgiaair.org/PagesByModel/892/M0039892.pdf
C bias voltage was usually - 4 1/2 volts. Might try adjusting this voltage for least distortion. Proper setting is determined by type of audio tubes and B+ voltage.
An audio interstage transformer can have an open winding and a radio will still operate distorted.
:Hello from a newbie in Idaho. The subject line says it all. I can't quite get a station tuned in without a bit of distortion. At low audio through headphones it sounds better. Any ideas would be appreciated.
:tnx.
:don
5/25/2012 10:10:56 AMTerry Decker
:tnx.
:don
You might try replacing the coupling cap feeding the signal to the output tube. This is usually a .05 from the plate of the previous stage to the output tube control grid.
5/25/2012 10:40:24 AMNorm Leal
Terry
That's a good idea for most radios. This one is older and output tube is driven by an audio interstage transformer.
::Hello from a newbie in Idaho. The subject line says it all. I can't quite get a station tuned in without a bit of distortion. At low audio through headphones it sounds better. Any ideas would be appreciated.
::tnx.
::don
:You might try replacing the coupling cap feeding the signal to the output tube. This is usually a .05 from the plate of the previous stage to the output tube control grid.
5/25/2012 11:59:35 AMTerry Decker
:Terry
: That's a good idea for most radios. This one is older and output tube is driven by an audio interstage transformer.
:::Hello from a newbie in Idaho. The subject line says it all. I can't quite get a station tuned in without a bit of distortion. At low audio through headphones it sounds better. Any ideas would be appreciated.
:::tnx.
:::don
::You might try replacing the coupling cap feeding the signal to the output tube. This is usually a .05 from the plate of the previous stage to the output tube control grid.
sorry-
I didn't check the schematic. This would be a good time to have a 'scope.
