RCA 29K
5/17/2012 11:24:31 PMJeff S.
I need some help determining the value of Cap C-16 in an RCA 29K I'm working on. The schematic lists the value as "2200" which doesn't correspond to anything on my capacitor cheat-sheet. I don't get a reading on my test meter from the one I pulled out of it, but size-wise it's bigger than the .005 caps in the unit. Since a 220 pf is a .00022 mfd, would the 2200 be a .0022 mfd cap?
Thanks for any advice///Jeff S.
5/18/2012 12:40:02 AMNorm Leal
Hi Jeff
Right C16 is called out as 2200. That would be 2200pf or .0022mf.
http://www.nostalgiaair.org/PagesByModel/878/M0014878.pdf
:I need some help determining the value of Cap C-16 in an RCA 29K I'm working on. The schematic lists the value as "2200" which doesn't correspond to anything on my capacitor cheat-sheet. I don't get a reading on my test meter from the one I pulled out of it, but size-wise it's bigger than the .005 caps in the unit. Since a 220 pf is a .00022 mfd, would the 2200 be a .0022 mfd cap?
:Thanks for any advice///Jeff S.
